Software that can integrate with RadioRA 2? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-28-2014, 08:19 PM - Thread Starter
aviphysics's Avatar
I noticed that Lutron has an integration protocol for RadioRA 2 and that someone wrote an Indigo plugin for it (http://jimandnoreen.com/?p=96#comment-11686). As inspiring as it was to see that it has been done, I am not a Mac user and don't ever plan to be. I do however have a power sipping media computer that hangs out right next to the RadioRA 2 repeater and is always on.
What I am trying to find out is whether or not any other software might be able to talk to the RadioRA 2 main repeater or might be possible for a user to make a plug-in for. Anyone have any helpful knowledge?
edit: I found a few possiblities to start with...
mControl supports RadioRa 2
Housebot supports scripts and RS232 in a way that should allow a user to develop something workable
Homeseer should also allow a RadioRa 2 plugin to be developed
Any other software out there?
aviphysics is offline
post #2 of 4 Old 03-30-2014, 12:48 PM
Dean Roddey's Avatar
Quoted: 406 Post(s)
Liked: 331
Our CQC product is Windows based and has a RA2/HWQ driver, so that might be an option for you (www.charmedquark.com).
Dean Roddey
Chairman/CTO, Charmed Quark Systems, Ltd
Dean Roddey is offline
post #3 of 4 Old 03-30-2014, 06:38 PM - Thread Starter
aviphysics's Avatar
CQC looks interesting. I like that you can control lighting through a map of the house.
What package would I need to integrate the following and what IR blaster/reciever would you recommend? (obviously some devices, like the Wii, can't be controlled by CQC in any way) I am thinking that the majority of control would be through an iPad, Android tablet, or Harmony remote. Can CQC pickup commands detected by the IR receiver in a Lutron Seetouch keypad?
RadioRA lighting and fan controls (RR dimmers, switches, fan controllers, pico, and seetouch keypads) (~ 30 devices)
Windows Kitchen computer (always on and running CQC software in background)
Toshiba LCD TV (attached to kitchen computer)
Android Tablet
Ipad
Denon AVR-1910 reciever
Harmony
The following output A/V through the Denon AVR
Home theater computer (on when needed)
PS3 (used as BR/DVD player)
PS4
Xbox 360
Wii
Epson Powerlight 1080 Projector ( can be controlled by IR or RS232 )
post #4 of 4 Old 03-31-2014, 12:58 PM
Quoted: 406 Post(s)
Liked: 331
That's getting pretty CQC specific, so probably best to sign up on the support forum and ask there. But it's doable.
Dean Roddey
Reply Home Automation
