RTI XP3 possible TELNET windows commands to shutdown. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-31-2014, 07:23 AM - Thread Starter
incadar's Avatar
Hi
i am trying to figure a way to shut down properly my Windows server based media server from my RTI panel when i select power off. only thing i can think off is to send a telnet command but not sure how to program or if my XP3 can do this, has anyone any ideas on this please?
incadar is offline
post #2 of 2 Old 03-31-2014, 09:00 AM
Super Moderator
markrubin's Avatar
Quoted: 1039 Post(s)
Liked: 2287
yes but you need a driver to do it: RTI has an unsupported third party driver to send one way IP strings:you need a passsword to access the site
http://forums.rticorp.com/index.php?topic=341.0
another way to do it is buy an IR receiver that plugs into USB port of server and send an IR command
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
Reply Home Automation
