Wired Home Alarm System Recommendations? - AVS Forum
 1Likes
  • 1 Post By Neurorad
  • 1 Post By crisms98
  • 1 Post By bigbarney
post #1 of 13 Old 04-16-2014, 04:27 PM - Thread Starter
roccoleach's Avatar
Quoted: 46 Post(s)
Liked: 32
My house is prewired for alarm, but has no system. I'm looking for something simple on the user panels (ie. hit one or 2 buttons to arm), but also, something with smartphone control/notifications?
Internet results proved confusing, like it's a secretive business. does there exists such a thing?
sorry if there's a thread already, search only seemed to return older threads
I have 16 zones, I do not wish to use wireless, and would like one motion sensor.
Also looking for something that can be used with, or without a service contract.
roccoleach is offline
post #2 of 13 Old 04-17-2014, 01:08 PM
Neurorad's Avatar
Quoted: 13 Post(s)
Liked: 86
You may get more opinions at cocoontech.com Home Security forum. Many of the posters there installed their own alarms.
roccoleach likes this.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 13 Old 04-17-2014, 03:56 PM - Thread Starter
roccoleach's Avatar
Quoted: 46 Post(s)
Liked: 32
Thank you!
post #4 of 13 Old 04-19-2014, 09:23 AM
crisms98's Avatar
I was in the same boat a few years ago and went with Elk M1. Installed it myself and there is an app for your smartphone. Also integrates with home automation systems if you decide to expand. My system has been solid for 7 yrs now.
longhorn85 likes this.
crisms98 is offline
post #5 of 13 Old 04-22-2014, 11:02 AM
tadr's Avatar
Another happy Elk m1 user here. Single button press to arm in away or stay. Type in code to disarm. Very easy to use. The flush-mounted KP2 keypads look nice and work great. I also recommend cocoontech - that's where I got all my info.
tadr is offline
post #6 of 13 Old 04-23-2014, 09:57 PM - Thread Starter
roccoleach's Avatar
Quoted: 46 Post(s)
Liked: 32
Thanks, that's what I'm leaning towards.
post #7 of 13 Old 04-24-2014, 06:44 AM
ekkoville's Avatar
Any of you with Elk systems use an automated deadbolt lock or anything?
ekkoville is offline
post #8 of 13 Old 05-13-2014, 10:59 AM
longhorn85's Avatar
I have the ability to with the zwave module but I don't right now. I use SmartThings to control my locks.
longhorn85 is offline
post #9 of 13 Old 05-13-2014, 11:07 AM - Thread Starter
roccoleach's Avatar
Quoted: 46 Post(s)
Liked: 32
My Almond+ is shipping this week! exciting
post #10 of 13 Old 12-01-2014, 02:31 PM
Zonker007's Avatar
Quoted: 12 Post(s)
How do you like your Almond+? I just got email that I can order one today for $189
Z
Zonker007 is offline
post #11 of 13 Old 12-01-2014, 04:23 PM
bigbarney's Avatar
Quoted: 135 Post(s)
Liked: 56
I like DSC better. Nicer touch pads. The upper one has a card slot and can do picture slideshows, and the lower one is a wireless talking pad. You can put anywhere in the house.
bigbarney is offline
post #12 of 13 Old 12-02-2014, 07:43 AM - Thread Starter
roccoleach's Avatar
Quoted: 46 Post(s)
Liked: 32
Z
I got the almost and liked it so much, I ordered that deal as a 2nd to use as a wifi extender. (i have 3 stories and a dedicated theater in the basement, and this has trouble getting signal in the theater).
I have only had one problem, and it has to do with my Sprint Airave (microtower), they were amazing with their concern and support, and i got to talk to one of the actual programmers, but due to my time constraints(Full time work and Full time school), I simply used my old wired router as a hub before the almond +.
post #13 of 13 Old 01-16-2015, 09:57 PM - Thread Starter
roccoleach's Avatar
Quoted: 46 Post(s)
Liked: 32
so i got my 2nd almond hooked up, and i'm running amazing speeds consistently throughout the whole house this is good news, now i can have all my widgets working properly.
Reply Home Automation
