Lutron Lighting Systems - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By spiwrx
post #1 of 8 Old 04-25-2014, 05:11 PM - Thread Starter
bankoms's Avatar
In the Lutron Homeworks or RadioRA2 systems, if you press a "Scene" button to turn on the scene, can you press it a second time to turn it off?
Also, I found some info on the older Grafik panels in other threads, but didn't find an answer to this question: can you still change a dimmer to a switch to control fans or vents?
bankoms is offline
post #2 of 8 Old 04-25-2014, 09:52 PM
jautor's Avatar
Quoted: 1319 Post(s)
Liked: 844
Yes, you can define the button (and therefore the scene) to be a toggle (forget the term in the software)...
Each zone (load) can be configured as a "non-dim" zone... Although I'd suggest looking for another way to control such things rather than consuming a GE zone for that... 12V trigger from the AVR is a good way to turn on fans/vents. I use the switched outlets on my power conditioner for this purpose (controlled by 12V trigger from the pre-amp).
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #3 of 8 Old 04-26-2014, 08:09 AM - Thread Starter
bankoms's Avatar
Thanks for the advice.  For a fan, you'd suggest putting the speed control switch in a two rocker panel, at an alternate location where a hybrid keypad is planned?
bankoms is offline
post #4 of 8 Old 04-26-2014, 11:12 AM
az1324's Avatar
Quoted: 24 Post(s)
Jeff
It doesn't seem like he is talking about rack/equipment closet fans but rather ceiling fans and or bathroom fans.
az1324 is offline
post #5 of 8 Old 04-26-2014, 01:54 PM
jautor's Avatar
Liked: 844
Agreed - I was just covering both cases. I wouldn't "waste" a GE zone on a ceiling fan or a vent, regardless.
jautor is offline
post #6 of 8 Old 04-26-2014, 02:00 PM
az1324's Avatar
Quoted: 24 Post(s)
Even if it was not needed for lighting?
az1324 is offline
post #7 of 8 Old 04-27-2014, 12:12 AM
jautor's Avatar
Liked: 844
Assuming the GE is being used for its intended purpose as a single room controller (likely for a theater), I bet there's a better use for it by dividing up another zone. But sure, if it's truly extra, go ahead...
jautor is offline
post #8 of 8 Old 08-05-2014, 02:18 PM
spiwrx's Avatar
Quoted: 87 Post(s)
Liked: 77
Yes, but please isolate with a small relay, this can be done for less than $10 and it will protect your $700+ Grafik Eye (or HW or RR2 Dimmer or Keypad). Lutron also sells a "interface" for this purpose. Only 1/2hp rated (more than enough for most fans) http://www.lutron.com/TechnicalDocum...ry/369-357.pdf
Most people set the zone to non-dim and this will work fine usually. But a problem with a motor will wreck the grafik eye, and it is simple for someone to take it out of non-dim mode and also potentially fry the Grafik eye when they try to "dim" a motor load.
jautor likes this.
Paul W.
'Lutron Grafik Eye & Radio Ra Specialist - or anything Lutron'
Hanks Electrical Supply
www.hankselectric.net
FB Page
paul@hankselectric.net
spiwrx is offline
Reply Home Automation
