Home Theatre Room Automation - Please suggest - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-11-2014, 11:41 AM - Thread Starter
Sam Ash's Avatar
Quoted: 216 Post(s)
I am of the opinion that Z-Wave is a good place to start in order to automate my home theatre room. I need to control all the AV gear from an iPad-Mini or iPhone. I also need basic light control (dimmers) that switch-on when I pause the movie and switch-off when I resume. I am not a programmer but have a good understanding of IT. Hence, I need an easy to use and easy to configure system. What controllers do you recommend ? - Vera Lite seems to be cost effective but then there is Fibaro Home centre lite and the SmartThings Hub. Furthermore, I have read good things about iRule and their excellent support.
All in all, I want a cost effective, easy to use, reliable and expandable system.
Any advice / help will be appreciated.
Sam Ash is offline
post #2 of 7 Old 05-11-2014, 01:12 PM
Dean Roddey's Avatar
Quoted: 388 Post(s)
Liked: 294
Actually, Z-Wave would have little to do with home theater automation, except perhaps for the lighting. The big problem with home theater automation is the gear itself, which Z-Wave doesn't address. Does any of your gear support serial or IP connections for control? That would be optimal. If not, you are down to IR control, which will be one-way control only, though you can make it more reliable than a remote control.
If it's all IR only, most of our customers would end up using something like a GC-100 for up to six zones of IR and a couple relays if you need that for screen control or something. You'd use stick-on emitters and set up CQC to invoke the commands required for various activities. And it would typically handle the browsing of media to select what you want to play as well.
If at least some of the gear is smart enough to have serial or IP control, then you can have two way control on those bits, which can be helpful for displaying status and reacting to changes in the state of the system (lights up on pause, lights off on playback startup, automatically set screen or lens for aspect ratio, that sort of thing.)
Dean Roddey
Chairman/CTO, Charmed Quark Systems, Ltd
www.charmedquark.com
Dean Roddey is online now
post #3 of 7 Old 05-12-2014, 01:19 PM - Thread Starter
Sam Ash's Avatar
Quoted: 216 Post(s)
Thanks for that Dean, I appreciate your input. Yes, my pre/pro and projector do have serial interfaces. My BD player, although WiFi capable, does not have either serial or IP interfaces, so I guess I will have to resort to IR for the BD player. I noticed that my specific pre/pro is covered by iRule and the brands of my projector and BD player are mentioned in the list of compatible devices. It would be nice to control the devices wirelessly using an iPhone or iPad Mini. Does that mean I have to buy a global cache device for each device ?
As far as the lights go, I only need to control the lights in my home theatre room in the manner that I've explained. Is there a way to do that with iRule without investing in a Z-Wave controller or Z-Wave compatible dimmers ? In other words, are there dimmers that can be controlled simply and directly via WiFi using iRule ? It would help to have small dimming devices that can be applied into wall boxes behind a switch (UK power ratings).
Sam Ash is offline
post #4 of 7 Old 05-12-2014, 02:14 PM
Quoted: 388 Post(s)
Liked: 294
I don't really know anything about iRule, so I can't help you there.
Dean Roddey
post #5 of 7 Old 05-12-2014, 04:10 PM
jautor's Avatar
Quoted: 1225 Post(s)
Liked: 787
iRule (and the other app-based remote controls) are TCP/IP (aka "Ethernet / WiFi"). If your device has an Ethernet / WiFi interface and a published, compatible API that iRule can talk to directly - that's all you need.
But for anything else, you'll need something to bridge between Ethernet/WiFi to the interfaces those devices support - meaning RS232 or IR. That is commonly done with a Global Cache product. You generally only need one of those per equipment stack / location. The GC-100, for example, can easily handle six IR-controlled devices and two RS232 devices. And in reality it can do more if needed. The cheaper iTach line works if you only need one interface type per location (everything IR-controlled).
First, IMO, you're NOT going to want to do it the way you described. A separate button for light control is better - and those buttons can be right next to each other - but separated so you don't HAVE to have the lights come up for a quick pause.
"Simple" - I'm not aware of any yet. But lots of ways to get there - although I don't know what's compatible in the UK (also - put your location in your AVS profile so it shows up in your posts - you'll get better advice in general). But the requirement all comes back to the control interface - if the dimmer has IP, IR, or RS232, you can use iRule to control it.
Jeff
jautor is online now
post #6 of 7 Old 05-12-2014, 11:43 PM - Thread Starter
Sam Ash's Avatar
Quoted: 216 Post(s)
Jeff
Hi Jeff, thank you very much indeed for your useful input. I guess it makes sense to go for the GC-100 and control the 3 devices (pre/pro, projector & BD Player), I suppose the GC-100 could be connected via ethernet to a wireless router.
Thank you for pointing out the lighting control issue, you do have a very valid point. For example, I may need to pause to answer my cell phone and I don't need the lights to come up in such a situation. Although, most times we need to pause because someone needs to grab a drink/snack or visit the washroom.
From the looks of it, I may need to get a controller device like the Vera Lite and some dimmers that can be installed in regular switch boxes behind the switches on the wall. I'm still researching to see if there are any WiFi based dimmers that can be applied in a similar manner an controlled by iRule.
Sam Ash is offline
post #7 of 7 Old 05-13-2014, 09:44 AM
newlinux's Avatar
Quoted: 27 Post(s)
http://www.amazon.com/gp/product/B008VW8NYE/ref=pd_lpo_sbs_dp_ss_3?pf_rd_p=1535523722&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B008VWAPU4&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0XVT0R39FA8XXHCFKDM2
Would fit the bill for dimmer control via vera. For a couple of bucks less you can get the one without energy monitoring. I have a number of the non dimmer versions of these behind my existing light switches.
I don't know about wifi based dimmers, but I do have an IR based dimmer in my theater room (predates my z-wave controller). Depending on your room's layout I would guess it would be possible to control the light using iRule and the GC-100. I'll be looking to do some more automation in my theater room and I'll be looking at iRule as an option (I currently just use a harmony remote, but a cool interface on my tablet seems fun smile.gif. iRule also has an integration with vera, IIRC.
newlinux is offline
Reply Home Automation
