AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Home Automation (http://www.avsforum.com/forum/162-home-automation/)
-   -   Making progress- amx thermometer any good (http://www.avsforum.com/forum/162-home-automation/1565609-making-progress-amx-thermometer-any-good.html)
yetis 06-13-2014 06:09 PM
So, quick question. Have bought the house and will spend really the next 9months preparing. However, house needs new HVAC,etc. I am likely going to go with amx. Any experience with their thermometers ? Any reason to avoid?
http://www.avace.com/pdf/ENV-VST-C_installation.pdf
trx250r87 06-17-2014 09:45 AM
If you like to make changes to your thermostat settings then this might not the thermostat for you. The user interface is terrible. I control my thermostat with my smart phone by opening a VNC connection to the AMX touchpanel. This is much easier than navigating the thermostat menu.
If you want to use the weather forecast option, a 3 year license is included, then I think you have to pay for use after the 3 years expires.
What other AMX equipment will you be using?
Eric
yetis 06-18-2014 08:47 PM
Eric
Thanks for the response. Hopefully a full suite of amx kit. I just purchased a house. It will be a year before we can get our ducks in order to do renovation, etc. but I will install new HVAC as existing systems are decades old and dying. So thought I would just get these in the interim.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
