Looking for HA Designer / Engineer - AVS Forum | Home Theater Discussions And Reviews
Old 07-05-2014, 09:09 AM - Thread Starter
punahou80's Avatar
Extensively renovating a home built in the 50s. Looking for a HA system designer.
I would like to work with an automation designer to develop single line diagrams for low voltage wiring and system components. An equipment and material schedule would also need to be developed prior to installation. All of this goes to the Architect who is designing the renovation. Any recommendations would be appreciated - please only provide these if you have actually worked with the person(s) on projects, etc. Location is Atlanta but IMO the designer doesn't have to be local.
Project will include:
low voltage wiring for HA, A/V, network, security (one chance to get it right)
DC microgrid for LED lighting inside house
Small solar PV array w/ plans for battery storage
Whole house A/V, media (possible home theater)
Lighting and daylighting controls (including shading)
Emphasis on energy management (HVAC, lighting, refrigeration, pool, plug loads..)
security system
New pool installation
outdoor + landscape lighting (hopefully DC)
solar water heating
One of my goals is to integrate all these systems into a single user interface. Please share your thoughts / advice.
punahou80 is offline
Old 07-06-2014, 11:13 PM
AVKING98's Avatar
Liked: 0
Glad to help you out!
Hello, My name is Tony Garnett. I ran across this post and wanted to offer our services to you. I'm the managing Partner of Select Audio Video in Baton Rouge Louisiana. I like to chat on the phone and speak to you about this project. I can be reached at my office anytime between 730-4. (225) 273-4521 or Selectaudiovideo@gmail.com
Thank you for your time. I look forward to hearing from you.
AVKING98 is offline
Old 07-07-2014, 05:48 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I would call Tony Golden, of Mobile Technology, in Alpharetta, GA, for help. If he won't do the design (too busy, or might not be willing to work with an end-user), he would have strong recs for someone else.
http://www.electronichouse.com/article/fit_for_a_king/
http://www.zoominfo.com/p/Tony-Golden/1243568341
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
