Any Z-Wave to Ethernet/WiFi Bridge/Repeater ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-20-2014, 12:49 AM - Thread Starter
geeji's Avatar
I am trying to install a centralized Z-Wave network in a large, multi-flats, building.
My problem : Z-Wave range inside a building is a paltry 20 feet, and I need at least ten-twenty times that end-to-end.
I tried a Z-Wave repeater (DSD37 from Aeon Labs), but it adds only 20 more feet, and you cannot have more than 4 of those sequentially.
So at that point, I am stuck.
What I would like is a "Z-Wave to Ethernet bridge" or a "Z-Wave to WiFi bridge" which would use longer range Ethernet (and power lines couplers) or WiFi to replicate the Z-Wave network transparently.
But after hours spent searching Internet, I could not find any.
It is especially frustrating since it seems all the hardware is there : for instance the RaZberry Pi or the Sigma Designs ZM5304 serial interface.
But it seems such DIY components need a lot of low level programming to achieve anything, and I need something closer to "plug & play".
I know I would probably be able to do what I want with multiple slaved Vera 3, but my budget goal is around $50 per (long range) repeater, not 4-5 times that.
Any suggestions ?
geeji is offline
post #2 of 9 Old 07-22-2014, 08:54 AM
Liked: 0
Home Depot and Amazon.com have the new Wink hub that might work or the Staples Connect both are only $49.99 are limited in what they do and are close to plug and play but might fit your needs.
Cfreeland is offline
post #3 of 9 Old 08-03-2014, 06:26 AM
Liked: 0
Your switches act as a repeater.
gmmeyerIII is offline
post #4 of 9 Old 08-03-2014, 11:09 PM - Thread Starter
geeji's Avatar
Thanks to both of you for the pointers, but I finally found something very close to the simple Ethernet<->Z-Wave bridge I was looking for : the SmartThings Hub
It is more expensive than the $50 or so I was aiming for (it is a full Z-Wave controller), but otherwise has most of the right attributes :
- Ethernet connection
- multi-hubs / multi-locations controller application on iOS
- multiple Z-Wave or ZigBee sensors/actuators supported
- compact box
- coming EU version (currently US only : 908MHz Z-Wave)
This kickstarter project, launched in 2013, has the right philosophy : heterogeneous protocols and sensors/actuators support, elegant "Apple-like" design, open programming environment, ...
I now have just to test it !
geeji is offline
post #5 of 9 Old 12-06-2014, 04:50 PM
HMenke's Avatar
Liked: 54
Great topic geeji. I'm already running InControl HA software from my HTPC with an Aeon Labs USB Z-Stick. Now I'd like to extend my Z-Wave network into my remotely located garage building. I have wi-fi over powerline out there with good local coverage and strong bandwidth, so I have been wondering how to set up an Ethernet-to-Z-Wave bridge in order to control Z-Wave devices out in the garage.
Have you made any further progress or discoveries? Can the SmartThings Hub be integrated into my existing control system or will I end up with a separate Z-Wave control system out in the garage?
HMenke is offline
post #6 of 9 Old 12-09-2014, 01:24 PM
aa6vh's Avatar
Multiple Vera controllers can be "bridged" together using ethernet. So you could have a seperate Vera in different areas that controls the modules in that area. The Veras then talk to each other via the ethernet connection. Check out the Vera support forum on bridging for details.
aa6vh is offline
post #7 of 9 Old 12-11-2014, 12:28 AM
turbotrdcelica's Avatar
NEXIA has repeaters that do a excellent job. I have a large home and have 2 repeaters ranging about 150ft total distance from the last zwave device to the Thermostat which is my zwave bridge!
turbotrdcelica is offline
post #8 of 9 Old 12-12-2014, 12:34 AM - Thread Starter
geeji's Avatar
@HMenke, @aa6vh : multiple SmartThings Ethernet hubs can be used in a single "location", in the same LAN or on different LANs, and each of those hubs can control multiple Z-Wave devices.
The issue then becomes the unit cost of those hubs ($99 for the SmatThings hub), which adds to the cost of the Z-Wave device, especially when you need 1 Ethernet hub for every Z-Wave device you connect...
@turbotrdcelica : thanks, but AFAIU, the Nexia repeater is just a regular Z-Wave repeater, which has all the limitations of the low power Z-Wave radio network : range within buildings is MUCH less than 150ft.
That's why I was looking for an Ethernet bridge.
geeji is offline
post #9 of 9 Old 12-12-2014, 06:35 AM
I have 2 repeaters and 1 bridge I have 150ft between the bridge and the last device which is a door lock, and motion detector. No problems communicating with the door or motion detector. From my personal experience, you are incorrect.
Reply Home Automation
