Looking for cheap, single source, remote extender - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-24-2014, 07:14 PM - Thread Starter
wfsaxton's Avatar
I'm just looking for an easy to way to get a signal to a single cable box, on the other side of a wall (where I've hidden it). From the placement of the receiver to the cable box is about 6'.
Will this do?: http://www.amazon.com/Infrared-Exten...te+transmitter
I'm just worried I'm not getting all the "hardware" and will have to buy additional stuff to get it to work.
Or...is there something I can plug directly into the cable box (instead of sticking a pad to the front of the remote receiver) to help facilitate this?
wfsaxton is offline
post #2 of 5 Old 07-24-2014, 07:39 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Can't vouch for the quality of that kit, but it's got everything you need if the wire is long enough.
Monoprice has a nice kit for <$20 that may be a better choice.
jautor is offline
post #3 of 5 Old 07-25-2014, 08:03 AM - Thread Starter
wfsaxton's Avatar
Got a link? I want to make sure I get the right one, heh.
wfsaxton is offline
post #4 of 5 Old 07-25-2014, 09:17 AM
jautor's Avatar
Liked: 777
http://www.monoprice.com/Product?c_i...seq=1&format=2
jautor is offline
post #5 of 5 Old 07-28-2014, 10:21 AM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
I can vouch for the Monoprice IR Extender Jeff referenced. I have (3) of them in my house, (2) with 50' 3.5mm extensions and the 3rd with a 75' extension, and they work fantastically with my U-Verse receivers.
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
Reply Home Automation
