We are building a new house with a BBB (Big Box Builder) that is almost complete. I want to do some level of home automation with out having to sell my kids, I want it to be in a reasonable budget.
Following are some details about the house
- 5 Bed / 4100 sft
- About 50 lights through out the home
- Has Cat5E cabling done to all rooms in the house
- Has Cat6 cabling done to 3 locations, 2 on first floor and 1 on second floor
- Is pre-wired for in ceiling speakers in 7 zones and will be hooked up to SONOS
- Have a 3" conduit that is run from the basement to attic for any additional cables I may need to run in future
Some things I want to be able to do
- Control lighting in various groups / scenes - both while at home and when I am about to come in to the home either from car or phone
- Have automated shade control through out the home
- Control and monitor HVAC while at home and away
- A nicety to be able to integrate Music into the system but not a biggie and I have no problem using Sonos's apps
- Do not need a central video system - will most likely play my media on 3-4 different locations using local network being served from a NAS
I have already talked to a local Crestron dealer and a rough quote to do lighting, audio, and video switching (3 TV's) came to about 25-30K. I am not looking to spend that kind of money. I have done some research and am leaning towards Lutron. Does this seem like the right option? I am reading up more to decide between Lutron Homeworks or Radio RA2 in my situation.
Suggestions are welcome and I am looking for some advice on how to approach this.
Most will say a system is only as good as the dealer and their ability to program the system. I have Control4 - the dealer did a poor job on the programming but I have hooked up with another dealer who is fixing all the problems and now I am enjoying the system much more.
Other than Crestron and Lutron you have Control4, Savant, RTI, URC, Elan and several others.
Most people will rave about the ones they own. Any of these can accomplish your goals of lighting, HVAC, audio and video distribution.
Sonos on Control4 is great, and Extra Vegetables just released an update to the driver to give you more functionality. For video distribution, some do it via a matrix and some put sources (cable boxes, apple tv or other wifi devices) local at each tv. Pros and cons to both set ups. Lighting - Control4 released new lighting this year which I have in my house. I have about 25 devices - a mix of dimmers, switches and multi button key pads. I got the engraved caps and they look sharp and function well.
My HVAC is controlled as well and its simple. I have sensors on the walls and my C4 thermostats are in the basement and I control everything via C4 interfaces (touch screens, remote control, phone app, etc)
Quotes will vary - if you the wiring is already done and you just need some hardware and programming, I think $25-$30k for Creston is likely a bit high but then again I've never priced Crestron hardware. What I should say is Crestron is one of the bigger more robust systems out there and they are programmed line by line for your house - so a lot of a quote has to do with programming hours. Systems like Control4 (and others) are more plug and play so they require less programming hours, but have some limitations with what they can control. That being said, 95% of residential installs are likely ok with any system from what I gather.
In the Control4 environment you still need a dealer to get started, but once up and running, you can do programming on your own - you just cannot add hardware on your own, you need your dealer for that.
Again, find a dealer you like and trust and you can see good work examples. Any of the systems I mentioned can accomplish your goals. I did not touch upon 100% DIY options as that is something I did not research when I made my decision.
I went the low budget route for lighting (if there is such a thing), and went with Insteon for all of our lighting. We have about 30 lights that are now Insteon, and we control them with our phones and PC via an ISY994i. I am currently looking at what to use for the HVAC setup. This route has been 100% DIY.
Are you looking to install / program this yourself, or have it done? Did you have a budget range in mind?
Lutron RadioRA2 will do everything on your list except the audio distribution. If you want a single, integrated user interface for all of those items, you'll probably at least need to move up into the Control4 realm and likely a dealer-installed system.
RadioRA2 you can completely DIY if you take the online training courses and are comfortable replacing light switches. WHA / music distribution can be accomplished separately (and DIY) with a number of systems - with a tradeoff of keypad/mobile functionality vs. cost.
- The 25-30K quote from the Crestron dealer included the hardware and AV equipment as well. The dealer suggested I get the equipment (speakers, tv's receviers etc) that he recommends as it is easier for him to program and also he knows how they function due to his prior experience. However, he was open to work with others
- Some of the things I got to learn were 1.3K for audio controller with 4 zones and 2.6K for 8 zone audio controller, 1K for programming touch panels per interface (iPad, Crestron remote etc)
- I want to keep the budget under 8-10K for any programming and the platform devices (such as the central unit, light dimmers etc). I am not counting any surround receivers, speakers etc
- I don't want to do any kind of video distribution and may want to just have separate boxes at each TV. I will have 3 TV's and they will play content off of a NAS
- I am very unhandy and have never really done any switch replacements etc. I am looking to have this installed by a dealer or a qualified professional.
- I want something that will allow me to grow and add on as the budget allows
The dimming outlets are nice too... I am using them for my rope lighting. The only thing is they will not turn a LED off as they let a little AC through to light the switch. I took care of that problem by getting this item and then using a cheater plug to adapt it to the Insteon dimming outlet.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
