Smart Hubs Comparison - AVS Forum
 1Likes
  • 1 Post By xtian08
post #1 of 8 Old 09-07-2014, 05:59 AM - Thread Starter
Liked: 1
Wink Smart Hubs Comparison
Just like to share this information I've collected. Image attached
shajan likes this.
xtian08 is offline
post #2 of 8 Old 09-07-2014, 09:54 PM
Quoted: 66 Post(s)
Thanks! Very nice to have the info.
Correct to assume all of these are IP gateways with some sort of "open" interface for 3rd party control?
audio2xs is offline
post #3 of 8 Old 09-08-2014, 08:39 AM
chadcj7's Avatar
Quoted: 17 Post(s)
out of these smart hubs which is everyone using and are you having good success? Also is anyone using these with iRule?
chadcj7 is offline
post #4 of 8 Old 09-08-2014, 11:04 AM
newlinux's Avatar
I'm using Vera, and I have had good success with it. I have around 40 or so z-wave devices. I have just started with iRule and have integrated it a little with Vera (using http calls, not the ViRule Vera module, so I didn't have to pay additional for that integration). I'm only controlling one Vera/Z-wave dimmer light with iRule, however.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
newlinux is online now
post #5 of 8 Old 09-08-2014, 06:03 PM
az1324's Avatar
Nice. You could add ISY. Iris is 99 on the Lowes site. Also would be good to see which require cloud connection, which support open api, custom scripting, and monthly fee.
az1324 is offline
post #6 of 8 Old 09-25-2014, 08:49 AM
Liked: 0
Thanks for the comparison!
HA22 is offline
post #7 of 8 Old 09-25-2014, 08:54 AM
Liked: 0
I have the SmartThings Hub but my neighbor just picked up a Wink. Is there a Wink forum or Wink user group on the net somewhere to help him?
HA22 is offline
post #8 of 8 Old 09-27-2014, 08:12 AM
jonasa's Avatar
Nice comparison!
You should check out Zipabox from Zipato also, it is rather new to the market and not all that developed yet, but looks really promising. I'm also surprised that you don't have Home Center from Fibaro on your list!
Another thing to look for is KNX compatibility. It is a widespread standard for smart home integration and supported by many electric hardware manufacturers all over the world!
jonasa is offline
Reply Home Automation
revolv , smart hub , smarthings , wemo , wink
User Tag List
