General Question about how to consolidate multiple switches into one scene controller - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-19-2016, 10:23 AM - Thread Starter
Negativecreep0's Avatar
Hey guys so I'm looking at insteon scene controllers. In my new construction kitchen i will have many switches (ceiling tray, can lights, pendant lights, under cabinet lights) How do I go about putting them all in one of those neat organized wall scene switches I see. How does it work generally. Do people put all the switches in a remote location like a basement utility room, then pair those switches to a scene controller located in the kitchen on the wall? Thanks for any help.
Negativecreep0 is offline
post #2 of 5 Old 07-19-2016, 10:47 AM
Liked: 1
Not a specific answer to your question, but the guidance I received was to put two keypad / scene controllers where rooms come together / at any external doors. That allows you to assign a single keypad to each room, which makes things much easier to use. For example, we put two keypads on the wall between the kitchen and the dining room - one controls the kitchen and the other controls the dining room. Same goes for between the kitchen and the backdoor - one does welcome/goodbye/external lights, and the other controls the kitchen lights.
JP14 is online now
post #3 of 5 Old 07-19-2016, 11:40 AM - Thread Starter
Ok so then did you have the primary switches for each light still on the main rooms wall? like kitchen you had a switch for the pendants, a switch for the ceiling cans, a switch for the cabinet under lighting etc.?
post #4 of 5 Old 07-19-2016, 12:32 PM
Liked: 1
We used combination keypads/dimmers. Although we didn't go with Insteon, it does look like they offer something similar.
We spread the hybrid keypads/dimmers around the room in the different locations where a keypad was needed. In the rooms where we needed additional lighting control (switch/dimmer) but didn't need another keypad, we put the switch/dimmer in a hidden location. Because it was just 2-3 places where this was needed, we did not centralize them - we just hid them in a closet close by the room where the light is.
JP14 is online now
post #5 of 5 Old 07-19-2016, 12:48 PM
Liked: 1
Also, lighting compatibility is not what it used to be when everything was incandescent - spend the time now before install to make sure that the lights are compatible with the dimmers. Lutron and Crestron offer compatibility information on their websites - I don't know how Insteon provides that information.
For us, the can and pendant lights were easy - took a bit of research to find compatible under cabinet lights.
JP14 is online now
Reply Home Automation
