Dome Camera? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By MOTILAC
  • 1 Post By jimmyv2000
post #1 of 6 Old 08-29-2017, 12:52 PM - Thread Starter
johnstonk's Avatar
Quoted: 35 Post(s)
Dome Camera?
I'm looking into picking up a POE Dome Camera for my Great Room and had a question. The low voltage Gang box is located on a vaulted ceiling, just past the peak of the wall. If I flush mount the camera will a tilting camera be able to get a level view of the room. I've never purchased/installed one, just don't want to return the camera for a bullet style.
Ken
johnstonk is offline
post #2 of 6 Old 08-29-2017, 06:48 PM
MOTILAC's Avatar
Quoted: 18 Post(s)
Liked: 9
Post a photo
MOTILAC is offline
post #3 of 6 Old 08-29-2017, 10:08 PM - Thread Starter
johnstonk's Avatar
Quoted: 35 Post(s)
Originally Posted by MOTILAC View Post
Post a photo
This is the best view of the camera's location & angle.
post #4 of 6 Old 08-30-2017, 09:25 PM
MOTILAC's Avatar
Quoted: 18 Post(s)
Liked: 9
Yes, a dome will be fine with that. You can adjust it to compensate for that.
johnstonk likes this.
MOTILAC is offline
post #5 of 6 Old 08-31-2017, 02:44 AM
jimmyv2000's Avatar
I have a dome camera mounted in a similar scenario as the original poster.
He should be good.
jimmyv2000 is offline
post #6 of 6 Old 08-31-2017, 09:33 AM - Thread Starter
johnstonk's Avatar
Quoted: 35 Post(s)
He should be good.
Thanks for the help!
Reply Home Automation
