ipad/tablet wall mounting - current best options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-03-2017, 09:35 PM - Thread Starter
bazfletch3's Avatar
Hi all
Just wondering if anyone has any other alternatives that might be better/cheaper for a wall mount tablet solution than the 2 options Im currently considering.
Essentially, Im looking at either a Launchport or Vidabox (vidamount). Obviously the Launchport provides the removable functionality, and does it very easily, but you pay LARGE for it...especially here in Australia (Im looking at $550 to furnish and iPad mini); the Vidabox seems like a solid good looking product, and comes in at closer to $200 here.
The other consideration is that Vidabox make mounts to suit other tablets, whereas Launchport will only fit an iPad, which further ups the total cost outlay. Is there any other alternatives to Launchport that suit a galaxy tab or other android tablet?
Ive spent the past couple of hours searching and goolging all over, and so far I havnt come up with anything better than these 2 - which may well be a reasonable conclusion...
Cheers
Barry
bazfletch3 is offline
post #2 of 2 Old 10-19-2017, 12:04 AM
Liked: 0
Have you looked at xvidia?
Sent from my Pixel using Tapatalk
Douglas Hernandez is offline
Reply Home Automation
