Nest for mini split AC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-20-2017, 07:21 PM - Thread Starter
jackforceus's Avatar
Quoted: 27 Post(s)
Can anyone of you help me with connecting a Nest thermostat to a mini split AC? I just bought a DuctlessAire 2 Ton Ductless Mini Split Air Conditioner and Heat Pump Variable Speed Inverter - 220V/60Hz. I would like to connect this to Nest. How do I connect? What interface do I need?
Please advice..
jackforceus is offline
post #2 of 8 Old 09-20-2017, 07:31 PM
Ash Sharma's Avatar
Quoted: 648 Post(s)
Liked: 509
Please advice..
I cant help with your question but I have a question about the voltage rating - does 220V mean you have to pull a special electrical line to power this unit (since home power is 110V).
Ash Sharma is online now
post #3 of 8 Old 09-21-2017, 08:32 AM
FlyingDiver's Avatar
Quoted: 208 Post(s)
Liked: 60
I don't think you can. Those units don't use standard thermostat wiring. In fact, there's no wiring at all. The controller is RF.
FlyingDiver is offline
post #4 of 8 Old 09-21-2017, 08:34 AM
Quoted: 208 Post(s)
Liked: 60
Home wiring (in the US) is 240/120. These units always require a dedicated circuit, they're not plug in units. A 240 line isn't really all that special. It's the same as used for more standard HVAC units, as well as cooktops, ovens, and dryers.
post #5 of 8 Old 09-21-2017, 08:59 AM
Ash Sharma's Avatar
Quoted: 648 Post(s)
Liked: 509
post #6 of 8 Old 09-21-2017, 09:27 AM - Thread Starter
Quoted: 27 Post(s)
Correct, You need to pull the 220 wiring from your main just like how you pulled for dryer, oven etc.
Coming to my main question, if I can connect the nest to mini split AC. It looks like the mini ac use milli-volts control and Nest uses 24V. If I can an interface / transformer to bridge that volts, then it might be possible correct?
Please see the link below:
http://ask.metafilter.com/305692/How...ir-conditioner
post #7 of 8 Old 09-21-2017, 03:31 PM
Quoted: 208 Post(s)
Liked: 60
Almost anything is possible, if you're willing to throw enough time, money, and effort into it. Unless the maker of the HVAC unit has a specific kit to use a "standard" thermostat, it's going to be difficult.
post #8 of 8 Old 09-25-2017, 08:01 PM
SMHarman's Avatar
Quoted: 371 Post(s)
Liked: 120
To expand you get three wires coming into your panel at a point in time these will be -120v, common, +120v
To get 240 you context to both hot and to get to 120 you take either hot and the common.
The electrician aims to balance loads to each side / phase of the board.
SMHarman is online now
Reply Home Automation
