Nutone to Nucleus - need electrical help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-29-2017, 01:47 PM - Thread Starter
h0mersimps0n's Avatar
My house was built in 2001 and has a NUTONE intercom system which I dearly hate.
I thought the cable run to the satellite intercoms was cat 5e but actually the cabling from each satellite intercom to the base station in my kitchen is proprietary nutone "IW-6 3PR 22AWG" cable. There are 3 twisted pairs (6 wires) - black/orange/red.
I want to install and power my Nucleus Anywhere intercom units using POE but ethernet cable is 4 twisted pairs and it looks like the power runs across all pairs and 4 pairs (8 wires) and 6 wires is not enough.
My base station in my kitchen is where all the satellite intercom cable runs to and there is AC wiring there so I could plug a POE switch in where the old NUTONE main box is.
Can anyone think of a way to send power through the Nutone IW-6 cables *safely* so I can power my Nucleus without having to pull wires?
h0mersimps0n is offline
post #2 of 2 Old 09-29-2017, 02:32 PM - Thread Starter
Looks like MODE A/B (supported by the POE switch I purchased) only requires 4 wires.
The switch I bought to run POE says on the back:
"POWER PIN:
[black square] Mode-A /1,2(+)/3,6(-)
[open square] Mode-B /4,5(+)/7,8(-)
using https://en.wikipedia.org/wiki/Power_...hernet#Pinouts
it's 22g wire so should be safe to run POE through regardless if it's NUTONE cable or not correct?
Reply Home Automation
