Rolling your own AMX or Crestron system - Page 3 - AVS Forum
post #61 of 63 Old 03-05-2009, 03:56 PM
CoffeeOverloaded's Avatar
Try Extron MLC 104 IP Plus or MLC 226. Software if free on there site and anyone can call for support. No username or password needed and you don't have to be a dealer. AMX and Crestron customer support is for dealer only, and same goes for their software. Sometimes Support is more important then looks. It just has to work, be simple and reliable. Also both models you can log in remotely and use the webpage GUI to control the system.
CoffeeOverloaded is offline
post #62 of 63 Old 03-05-2009, 04:00 PM
O, with GC software that's used for Extron controllers, you don't have to program anything, it's configuring only. What does that mean? It means you don't have to be a programmer and don't need to learn new code.
post #63 of 63 Old 03-12-2009, 11:14 AM
CJO
CJO's Avatar
You do realize that this thread was from 2006?
CJ
coneilliv at aol dot com
The Dark Knight Theater
(a bunch of good reference links and material in first 15 posts)
CJO is offline
Reply Home Automation
User Tag List
