Insteon questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-23-2007, 09:30 AM - Thread Starter
clear33765's Avatar
Is it possible to buy only 1 or 2 or 3 INSTEON SwitchLinc V2 Dimmers and control them with a RF universal remote control like the Harmony 890 or URC MX-3000 without the need for any other equipment?
Are there any other master control box that Insteon requires or can I just purchase the dimmers?
For a three way switch, does the Insteon dimmer need a companion at the other end like the Lutron RadioRA dimmers?
I've been looking at home lighting options for awhile. The Lutron RadioRA is expensive and requires a specific controller box to communicate the lights with a third party universal remote. I'm just wondering if Insteon works the same or differently.
I'm just looking for basic light operation. Although the capability to set timers and maybe control over the Internet a possibility down the line.
clear33765 is offline
post #2 of 5 Old 01-23-2007, 11:16 AM
CalypsoCowboy's Avatar
As I understand Insteon now, no, you would need more hardware to control the lights. I think you could get a couple of switches, program them with an X10 address and then use a IR-x10 bridge to control them. As for controlling without other equipment you may look into zwave as I think some of the Harmony remotes can control Zwave switches.
All men are animals, some of us just make better pets.
Moose Drool Moovie Theater
CalypsoCowboy is offline
post #3 of 5 Old 01-23-2007, 02:29 PM - Thread Starter
clear33765's Avatar
Insteon dimmers are both RF and powerline.
Why would I need an X10 IR bridge? The MX-3000 and Harmony 890 are both capable of RF signals. Are RF universal remotes not capable of sending RF signals the dimmers can understand?
post #4 of 5 Old 01-24-2007, 02:45 AM
Sendero's Avatar
Because Insteon isn't really RF Not all of the Insteon devices send/rec RF. My understanding is that only the SignalLincs actually do that, and only to repeat commands on the 'insteon network'. The other devices just use the powerline. So, in order to get the signal from your remote to the powerline you'll need a bridge.
Sendero is offline
post #5 of 5 Old 01-24-2007, 08:05 AM
herdfan's Avatar
Or you could get this ugly beast when it becomes available:
http://www.cocoontech.com/index.php?...=post&id=56133
Please do not send me PM's asking for software! You will not get it.
herdfan is offline
Reply Home Automation
