Touch Screen Wall Docking Options - UMPC, Airpanel etc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-28-2007, 08:43 AM - Thread Starter
jaynma's Avatar
I've been trying to settle on a touch screen solution for my home automation install. I'd like to utilize 2 or 3 wireless UMPCs or similar as my touchscreen controllers (using a PC client for my controller, leveraging a wireless LAN)
I would much prefer to have these screens docked in the wall charging most of the time, but maintain the flexibilty of using their wireless functionality.
I've seen the viewsonic models, but not sure if the Creston Mount/dock works with the standard viewsonic form factor or not (is the airpanel that Crestron private labels any different than an standard airpanel?) Could I buy a standard Airpanel and a Creston Mount? (I'm not using a Crestron contoller)
What about UMPCs - anyone seen a flush wall mount for any of the models on the market? I've love to find something for the Samsung.
Any other solutions/ideas? Favorite devices?
I've been looking and reading, but can't seem to find something that will work.
thanks in advance!
jaynma is offline
post #2 of 5 Old 01-28-2007, 08:59 AM
IVB
IVB's Avatar
In the "for the cheap folks" category, i'm using a wallmount Fujitsu 3400. There's also folks who've flushmounted these by cutting larger holes in the sheetrock.
It is clearly a level below most of what you see out there, probably 2 levels below a UMPC. I know folks have been happy with the Samsung Q1 UMPC, and there's folks out there producing wallmount panels for them.
Yes, I'm "that" Home Automation Guy.
IVB is offline
post #3 of 5 Old 01-28-2007, 11:17 AM
WayneDB123's Avatar
I have a couple of Fujisu Stylistics also and just wanted to add the also cheap C-500 LT makes a nice table top controller, 8.4 inch nice bright screen.
WayneDB123 is offline
post #4 of 5 Old 01-28-2007, 09:30 PM - Thread Starter
jaynma's Avatar
Anyone found wallmounts for the Samsung UMPC? How about mounts for any of the other UMPCs?
jaynma is offline
post #5 of 5 Old 01-28-2007, 10:04 PM
IVB
IVB's Avatar
One thread about producing wall & dockmounts for the Samsung.
IVB is offline
Reply Home Automation
