Single Gang IR Keypad? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-09-2007, 04:35 PM - Thread Starter
dwightk's Avatar
I am looking for a single gang keypad that I can mount into a J-Box in a wall to send IR signals (on/off Volume Up/down) to an IR controlled amp. The keypad has to be IR teachable ( or IR learning???).
I know that Xantech & russound both have double gang keypads that do this, but they are overkill and more expensive than I would like.
any suggestions?
dwightk is offline
post #2 of 2 Old 03-10-2007, 10:50 AM
Cassius's Avatar
if I remember correctly, the Uno S1 from Russound is single gang. That should do exactly what you want.
Price is ~$100
Cassius is offline
Reply Home Automation
