Homeworks Software & DST - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-12-2007, 05:52 PM - Thread Starter
imaohw's Avatar
Does anyone know where I can get updated software for my Homeworks Interactive Processor to deal with the DST issue.
I can't find the original installer so that is not an option.
imaohw is offline
post #2 of 2 Old 03-13-2007, 04:03 AM
jkv
jkv's Avatar
you don't need new s/w, you just need to edit the DST rules with the existing s/w. If you have the HomeWorks s/w, you can pull the programming out of the panel, edit the rules and then reload the panel. If you don't have HomeWorks, you will need to find a Lutron dealer to help you out.
you can PM me if you have any questions
HTH
Riverside Cinemas
jkv is offline
Reply Home Automation
