X10 Lighting controlled by Crestron - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-22-2007, 09:55 PM - Thread Starter
da_pirate's Avatar
Is this possible? Has anyone been successful integrating X10 or Insteon lighting using crestron processors? Any help would be more than appreciated. Thanks
Crestron Certified Programmer
da_pirate is offline
post #2 of 10 Old 05-23-2007, 06:32 AM
Brent McCall's Avatar
http://www.appdig.com/adicon_new/ocelot.htm
Check this out.
Brent McCall
Not A Dealer
Brent McCall is offline
post #3 of 10 Old 05-23-2007, 12:15 PM
maddogmc's Avatar
Check this out.
I can vouch for the Ocelot with X10 and IR. I have one in my home handling about 40 X10 switches and plug-in controllers. I use time-of-day, sunrise/sunset and x10 line commands in various situations along with some logic. I also have one in my elderly mother-in-laws home to turn on/off the TV and set various channels based on time of day.
A nice product, low cost and relatively easy to program.
"I'm a fanatic without a cause and I believe in it!" - B. D. G.
maddogmc is offline
post #4 of 10 Old 05-23-2007, 12:36 PM
IVB
IVB's Avatar
If you can afford to have someone put in a Crestron system, why would you use X10/Insteon, and not something nicer?
Yes, I'm "that" Home Automation Guy.
IVB is offline
post #5 of 10 Old 05-24-2007, 06:21 AM
herdfan's Avatar
My thoughts exactly.
Please do not send me PM's asking for software! You will not get it.
herdfan is offline
post #6 of 10 Old 05-24-2007, 07:31 AM
Zwave's Avatar
I would look into Zwave, Powerline would be a problem in a house with crestron
Zwave is offline
post #7 of 10 Old 05-24-2007, 11:29 AM - Thread Starter
da_pirate's Avatar
From what i've heard Insteon works pretty well considering... Unforutanetly, since I am the crestron installer, I was simply trying to consider ways to incorporate into my personal system at the lowest cost. I'm not paying tons of money to have someone install the system. It's already there.
But reading the comments, I'll just probably hold off and implement a Radio Ra solution.
post #8 of 10 Old 05-24-2007, 11:37 AM
smoothtlk's Avatar
Try Insteon and the new PLM controller. If you are a Crestron programmer, you might be able to figure out the RS232 commands directly with Crestron processor.
Not as good as a high end hard wired system, but for what you are trying to do, should be just fine (the Insteon portion and hopefully the integration with Crestron).
CEO
Allonis LLC
smoothtlk is offline
post #9 of 10 Old 12-18-2011, 08:11 AM
Wang191's Avatar
I was able to figure out the x10 protocol and I can now send x10 lighting commands via an insteon rs232 interface and crestron processor. It's a little unreliable because of the way the commands hva to be sent and the way I programmed it. It needs work but it can be done.
Wang191 is offline
post #10 of 10 Old 03-26-2013, 02:17 AM
Addemar Romero's Avatar
i want to integrate insteon lighting system with crestron... what do i need? a 2413S or a 2410S interface...to control insteon via RS232 and is there any posibility to control it by IP
Addemar Romero is offline
Reply Home Automation
