Insteon & CFL - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-06-2007, 08:16 PM - Thread Starter
blangstaff's Avatar
I've been an X10 user for many years, and for many reasons am considering a switch to Insteon. Can someone please share experieneces with Insteon and CFL. I've phoned Insteon tech support and was told the two don't work together. When pressed a little, the tech said that some work and some conflict. He explained that some bulbs interfere with the signal. So am I making a mistake forcing the issue?
blangstaff is offline
post #2 of 3 Old 06-06-2007, 08:51 PM
AccessHA's Avatar
I would take Smarthome's advice. Insteon generally does not play well with CFL.
AccessHA is offline
post #3 of 3 Old 06-07-2007, 04:31 AM
MikeB1973's Avatar
Experiences seem to be mixed, and I believe X10 has the same potential issues. So if you're using CFLs with X10 and reliability is high, I believe you should be OK with Insteon as well.
Some CFLs cause excessive noise on the powerlines that can interfere with powerline signals. I believe some brands are simply worse than others, and depending on what else is going on in your powerlines it might be too much noise.
I personally have a bunch of CFLs installed, and my signal reliability is very high.
MikeB1973 is offline
Reply Home Automation
