Any PowerRise Hunter Douglas Motorized Shade Experince Here? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 133 Old 12-14-2013, 12:32 PM
joealbracht's Avatar
The Platinum Gateway was announced this September. It appears to be an expanded version of the prior Platinum Bridge Kit (same form factor). It adds 3rd party access to control Platinum 2.1 battery operated shades. Home automation systems can send any/all of IR/IP/RS232 commands to the Gateway which than uses RF to operate the shades. I am waiting on one but am told HD has not yet shipped the new Gateways. My latest update is to hope for shipment this coming week.
ETA: It appears that only predefined scenes can be invoked via the Gateway, nothing adhoc.
joealbracht is offline
post #92 of 133 Old 12-16-2013, 06:58 AM
AV_Integrated's Avatar
Quoted: 973 Post(s)
Liked: 718
Any idea if that controller will work with the PowerRise shades which are not 2.1 but are still RF controlled?
I have the mini-cellular shades, battery operated, with up/down commands, and up to four groupings of shades that I would like to control... however. I can do contact closure, IR, RS-232, Ethernet, etc., but I can't get a wire to the shade itself. I can attic store the controller, or put it in a closet and get a wire to it.
I've bought a second remote control, that I've disassembled and wired up for control, but would prefer a cleaner solution... A much cleaner solution.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #93 of 133 Old 12-16-2013, 04:56 PM
z2020's Avatar
I am using the platinum app (not Gateway) and love the control with all the scheduling options. I hope to interface with ElanG! home automation using the Platinum Gateway. What system are you connecting HD to? Should I be able to run the same schedules with the automation connection? Please post when you get your Gateway up and running. This has been difficult to track down I guess because it is so new. Thanks.
z2020 is offline
post #94 of 133 Old 12-16-2013, 05:14 PM
DonsDraperyInc's Avatar
The Gateway has been released and is shipping out. It looks just like the "bridge" you are using to control your shades with the app. Only Hunter Douglas "Certified Motorization Specialists" can order the part. They work just like the bridge when you use your ipad or iphone. However home automation systems can actuate the scenes you create using ip, serial (rs232), or IR. If needed I would be happy to provide one for you. You can PM me for a price quote they are surprisingly affordable.
DonsDraperyInc is offline
post #95 of 133 Old 04-18-2014, 04:35 PM
Club Chapin's Avatar
I just received a Platinum Gateway. I pretty cool product. Unfortunately, my Platinum Gateway did not include the User Guide, just the Quick Start Guide. The Quickstart lists the 232 commands but not the IP commands. It refers to the User Guide for the IP information.
Does someone have this info they can point me to? Maybe a pdf of the User Guide would be available somewhere? I've searched and connot find it, just the quick start guide, which I already have.
Ultimately, I am looking for the IP command set.
Thanks, Pete
Club Chapin is offline
post #96 of 133 Old 04-18-2014, 09:15 PM
IP and RS232 commands are the same.
As of a few months ago, the User Guide did not exist.
The Gateway does work. However, the Platinum App (the interface) used to define the scenes is quirky. I spent some time testing how the App & Gateway work (documentation is VERY limited and incomplete), wrote down all the scenes I needed, reset the Gateway and entered all the scenes into the Platinum App. If you need to use RF extenders, properly locating them is key & may take experimentation.
All the data lives on the Gateway so you can any number of iPhones/iPads/etc. to do the updates. Unfortunately, no way to backup the Gateway.
Club Chapin likes this.
post #97 of 133 Old 04-22-2014, 08:10 PM
Thanks. I got this to work. I did have some correspondence with HD. Like you mentioned, the User Guide does not exist. They did finally send me an IP PDF that, as you indicate, is the same as the 232. It does indicate a different end of string character, but both the 232 and TCP end of strings work.
I had tried this before with no luck, using a dos telenet connection. I had tried the 232 commands prior, but they didn't work. I could see it acknowledging commands from the ipad, but it wouldn't respond to my sent commands. Today, after receiving the sheet, and before looking here and seeing your response, I connected with putty and was able to control these TCP.
Now to figure out how to get my control system to send these commands.
I've attached the pdfs for setting static IP and TCP control.
Pete
PlatinumGateway_IP.pdf 302k .pdf file
SettingStaticIPAddressGateway.pdf 39k .pdf file
post #98 of 133 Old 04-22-2014, 08:22 PM
Does anyone know if the Platinum Gateway and the wired connection interface (PCN 4254220005) can be used simultaneously? I'd like to add the simple wired Platinum Switch (PCN2951710000) to my shades for local control.
Where I bought my shades said they cannot, but I am not convinced they really know. They didn't have a clue about the Platinum Gateway and how to control it other than with the iOS app.
Thanks, Pete
post #99 of 133 Old 04-23-2014, 12:55 PM
az1324's Avatar
Quoted: 24 Post(s)
Maybe, but seems like a lot of trouble to avoid using the wireless wall switch just because it has some extra buttons.
az1324 is offline
post #100 of 133 Old 04-23-2014, 02:14 PM
Yes and no. At the same time it adds a contact closure interface (I do not need) and hardwires the 18v (eliminating batts) for the shades.
And, both functionally and visually, it is a lot cleaner and simple for everyone, including guests, to operate.
I'm the guy that gets annoyed that I cannot delete Sirius, which I don't subscribe to, from my car's interface.
I've got no need for extra buttons.
post #101 of 133 Old 05-14-2014, 06:24 PM
denver24312's Avatar
Pete
Have you found a way to list any of the other commands available?
denver24312 is offline
post #102 of 133 Old 05-17-2014, 12:17 PM
z2020's Avatar
See next posting.  Sorry, could not figure out how to correct entry then delete it.
z2020 is offline
post #103 of 133 Old 05-17-2014, 12:29 PM
z2020's Avatar
I have been using the HD Platinum GATEWAY with the iPad - iPhone APP.  I replaced the HD Bridge with the Gateway which works the same as the Bridge but has an RS232 connection.  I love it.  It works great.  BUT ... we are controlling our home with Elan g! and our Elan guy does not know of an available software interface. Does anyone know the status of Elan g! talking with the HD Platinum Gateway or have a way for me to get the two talking?  I would like to have the Elan system run the HD Gateway.  Thanks.
z2020 is offline
post #104 of 133 Old 05-17-2014, 05:41 PM
The HD Gateway can be controlled by sending commands to the Gateway via RS232, IP and/or IR. I know nothing about Elan but their literature says their controllers have (at least) RS232 and IR outputs. Why can't the Elan send commands to the HD Gateway?
post #105 of 133 Old 05-20-2014, 09:13 PM
I'm not aware of the existance of other commands. They may exist, but I have no idea what they are or how to decode them.
post #106 of 133 Old 05-20-2014, 09:16 PM
My gateway closes the shades about 90 mins before sunset when set to close at sunset. HD has had me try a bunch of things, but nothing resolves it.
I see that there is a "reset" button, but it does not seem to reset the gateway. Does anyone know how to reset it? I've held for 10+ second, and have rebooted while holding it and in both cases, the settings are still in the thing. I don't see any info on any of the documentation about the gateway.
Also, what does the middle button do? The outside one is for ID'ng and testing the repeaters, correct?
Thanks, Pete
post #107 of 133 Old 05-20-2014, 10:36 PM
Figured this out. Found a booklet titled GatewayKitBooklet and it says the following:
"Press the P button on the back of the Platinum Gateway. The light on each Platinum Repeater should turn GREEN.
Other controls on the back of the Gateway include the RESET button, which reboots the Gateway; and the X button, which erases all your data from the Gateway when pressed for 6 seconds."
It seems that the "X" button is behaving as I would expect the "RESET" button to behave.
At anyrate, the "X" button nuked my settings. Maybe sunset will work correctly now for me.
Pete
post #108 of 133 Old 05-21-2014, 08:16 AM
Sunrise & sunset times depend on longitude and latitude. I see the Platinum App does make use of the Apple device's location services and, I assume, tells the gateway. Make sure you have enabled location services on your Apple device and that the Platinum App is using it. Other than that, no ideas.
post #109 of 133 Old 05-30-2014, 05:52 PM
I have frequent problems with DHCP not working when the HD Gateway reboots so I want to move to using a static IP address which it outside of the router's DHCP range. I can send the RS232 commands you provided to change the HD Gateway to a static IP address & IP is fine until the gateway reboots for any reason. When the gateway reboots, it goes back to using DHCP and I have to resend the static IP commands to ensure IP works. I wouldn't care but the controller that sends the serial commands doesn't know when the gateway reboots and needs to receive the commands again to ensure the gateway's IP is in a working status.
questions:
1. Does your gateway ever have problems with DHCP?
2. Does your gateway stay in static IP mode across reboots?
post #110 of 133 Old 06-04-2014, 12:56 AM
tannewt's Avatar
I haven't noticed any dhcp issue but my gateway doesn't get restarted often. You can usually set your dhcp server to always give it the same address if you want it to always be at the same IP but can't get the gateway to keep its settings.
Has anyone tried intercepting the network communication from the app in order to learn more commands? There is also some discovery piece that is happening too so that the app can find the ip of the gateway. Any idea what that is?
tannewt is offline
post #111 of 133 Old 08-04-2014, 11:49 PM
tannewt's Avatar
Protocol basics
I've reverse engineered a bit of the protocol and documented it here: https://github.com/tannewt/agohunterdouglas
It was pretty easy to do by snooping the IP traffic from the app to the gateway.
tannewt is offline
post #112 of 133 Old 08-05-2014, 01:49 PM
az1324's Avatar
Quoted: 24 Post(s)
Cool. Can you post an example communication log?
az1324 is offline
post #113 of 133 Old 08-06-2014, 12:29 AM
tannewt's Avatar
Here is the log I was basing it off of. My comments start with #, input starts with $ and 1 $ is output.
Code:
$dat
1 $mbc100-100-100-100-
1 $firm01-2018-HD gateway 2.18
1 $MAC0x000000000000-
1 $LEDl064-
1 $upd00-
1 $reset
1 $set006-
1 $ctVt<garbage>
# rooms
1 $cr00-01-0x0150-Living Room
1 $cr01-02-0x0D1A-Master Bedroom
1 $cr02-01-0xF5CA-Office
# shades
1 $cs00-00-06-Living Room 1
1 $cp00-04-000-
1 $cs01-01-04-Master Bedroom 1
1 $cp01-04-000-
1 $cs02-01-01-Master Bedroom 2
1 $cp02-04-000-
1 $cs03-02-05-Office 1
1 $cp03-04-189-
1 $cs04-01-05-Master Bedroom 3
1 $cp04-04-000-
1 $cs05-01-06-Master Bedroom 4
1 $cp05-04-000-
1 $cs06-00-08-Living Room 2
1 $cp06-04-000-
1 $cs07-00-03-Living Room 3
1 $cp07-04-000-
1 $cs08-00-01-Living Room 4
1 $cp08-04-000-
#scenes
1 $cm00-Wake Up
1 $cq00-01-01-
1 $cq00-02-01-
1 $cq00-04-01-
1 $cq00-05-01-
1 $cx00-01-18-053-01-
1 $cm01-All Open
1 $cq01-00-01-
1 $cq01-01-01-
1 $cq01-02-01-
1 $cq01-03-01-
1 $cq01-04-01-
1 $cq01-05-01-
1 $cq01-06-01-
1 $cq01-07-01-
1 $cq01-08-01-
1 $cx01-00-04-255-01-
1 $cx01-01-04-255-01-
1 $cx01-02-04-255-01-
1 $cm02-All Closed
1 $cq02-00-01-
1 $cq02-01-01-
1 $cq02-02-01-
1 $cq02-03-01-
1 $cq02-04-01-
1 $cq02-05-01-
1 $cq02-06-01-
1 $cq02-07-01-
1 $cq02-08-01-
1 $cx02-01-04-000-01-
1 $cx02-02-04-000-01-
1 $cx02-00-04-000-01-
1 $cm03-Living Room Open
1 $cq03-00-01-
1 $cq03-06-01-
1 $cq03-07-01-
1 $cq03-08-01-
1 $cx03-00-04-255-01-
1 $cm04-Office Open
1 $cq04-03-01-
1 $cx04-02-04-255-01-
1 $upd01-
# invoke a scene
$inm04-
1 $act01-00-
1 $cp03-04-255-
1 $act02-02-
1 $act00-00-
# dummy ping
$dmy
1 $ack
# setting a shades state
$pss03-04-125
1 $act01-00-
1 $cp03-04-125-
1 $done
# activates all shades to transition to the previously defined state
$rls
1 $act02-02-
1 $act00-00-
$pss03-04-191
1 $act01-00-
1 $cp03-04-191-
1 $done
$rls
1 $act02-02-
1 $act00-00-
000 is all the way down
255 is all the way up
# 18 is for the middle rail of tdbu shades
$pss04-18-192-
1 $act01-00-
1 $cp04-18-192-
1 $done
$rls
1 $act02-01-
1 $act00-00-
$pss04-18-255-
1 $act01-00-
1 $cp04-18-255-
1 $done
$rls
1 $act02-01-
1 $act00-00-
$pss04-18-000-
1 $act01-00-
1 $cp04-18-000-
1 $done
$rls
1 $act02-01-
1 $act00-00-
000 is the top at the top
255 is the top all the way down
tannewt is offline
post #114 of 133 Old 08-10-2014, 07:18 AM
This is awesome. Thanks for sharing and posting this.
post #115 of 133 Old 08-10-2014, 07:20 AM
That is how it is meant to function. Apparently there are some scenarios where this doesn't work. They have replaced one gateway with another, only to have it behave the same. They say they have found a bug that they are are fixing with a software update. Not sure how gateways are updated. Maybe automatically via the platinum app?
post #116 of 133 Old 08-10-2014, 07:24 AM
questions:
I actually never set up the static IP. Instead, I have a DHCP reservation set up for that mac address on my router. This eliminates questions around static IP behavior with the gateway. I expect it should work and would expect a static address to survive a reboot.
Pete
post #117 of 133 Old 10-14-2014, 10:16 PM
jackass124's Avatar
Pete
Hi! Been following this thread because I'm about to get some hd blinds...wondering if it's possible to get the motorizations installed without the platinum stuff and then use some third party home automation solution like Belkin wemo to control scheduling and stuff....
jackass124 is offline
post #118 of 133 Old 10-15-2014, 07:43 AM
jeffgojeffgo's Avatar
Without the Platinum Gateway (the "Bridge Kit"), then you'd need to find a third-party system that understands what RF commands to send to the windows coverings to control them (open, close, up, down, tilt, slant, etc.).
The Platinum Gateway is the magic piece that makes third-party control possible. If you're geeky enough, you can roll your own stuff to do that, otherwise you need to rely on a third party that's created a system to integrate the HD Platinum with WeMo, Insteon, etc. Control4 (control4 [dot] com) may be doing that, from what I see.
Being geeky enough, I've written a program that integrates my HD Platinum controlled shades with my CentraLite lights, Venstar thermostat, and Insteon system, giving me one web based interface to all of them. That was only possible because each system has its own "controller" or "hub" or other interface. Leaving out the Platinum Gateway would have made it impossible for me to integrate our window coverings into my system. I used the Platinum App only once, on the day the HD window coverings were installed, and did nothing but use it to define the shades that I have. After that, everything has been controlled by my custom system.
I'm not sure what the Platinum Bridge Kit costs from your HD dealer, but you can usually find it for sale on eBay for $200 - $250. But you need to be sure that the HD motorized window coverings you buy will be controllable by an RF remote, not and IR remote, and that they're compatible with the Platinum App. After what the HD motorization adds to the cost of your window coverings, the cost of the Bridge Kit directly from HD is really pretty minimal.
jeffgojeffgo is offline
post #119 of 133 Old 10-15-2014, 04:28 PM
jackass124's Avatar
Thanks for the info!...so if i am only motorizing 1 window...just make sure it has RF capability for the Platinum App if I want to upgrade it in the future? is that what youre saying? I'm motorizing a larger sized top down bottom up cellular Applause blind...I want to make sure if Apple's Homekit or Wemo is eventually compatible with Hunter Douglas, that I have it as an option....for scheduling the blind opening and closing.
post #120 of 133 Old 10-15-2014, 04:40 PM
trmoore2's Avatar
Quoted: 107 Post(s)
Liked: 48
Motorized shade
I just put in a Roman shade 9 feet wide by 6-7 tall. The motor is by Somfy and works great. Roman shade goes up/down instead of side to side. Total darkness with the side fabric panels.
trmoore2 is offline
Reply Home Automation
