Any PowerRise Hunter Douglas Motorized Shade Experince Here? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 133 Old 10-15-2014, 03:46 PM
jeffgojeffgo's Avatar
Originally Posted by jackass124 View Post
Thanks for the info!...so if i am only motorizing 1 window...just make sure it has RF capability for the Platinum App if I want to upgrade it in the future? is that what youre saying? I'm motorizing a larger sized top down bottom up cellular Applause blind...I want to make sure if Apple's Homekit or Wemo is eventually compatible with Hunter Douglas, that I have it as an option....for scheduling the blind opening and closing.
Yes, you definitely want a Platinum App compatible (RF) window covering. Two reasons: First, if it's not Platinum compatible now, it (almost certainly) won't be in the future. Second, the HD RF remote is way better than the IR remote (speaking from experience).
I think that in the future we'll see more and more third parties integrating HD window coverings into their systems, especially as more and more people have compatible window coverings. There's probably a little chicken-and-egg thing going on at this point (if not many people have the appropriate HD shades, why would a company bother spending the time and money integrating it into their system?).
If you have a Platinum App compatible shade (or shades) but no Bridge Kit, and later find a company that's integrating the HD system, you can always buy the Bridge Kit at that time.
jeffgojeffgo is offline
post #122 of 133 Old 10-15-2014, 04:14 PM
jackass124's Avatar
My blinds installer says the remote that comes with the motorization is BOTH RF and IR...is that true? or are there really different kinds of remotes? he read me documentation stating that...and he says it's totally upgradeable in the future if i want to add the bridge kit at a later dat
jackass124 is offline
post #123 of 133 Old 10-15-2014, 04:51 PM
I hadn't realized it before, but the remote I have is both RF and IR. It's a "Platinum Technology" remote "for PowerRise, PowerGlide, and PowerTilt Systems". So that remote will work for both RF and/or IR window coverings. You want to be sure that the window coverings have the RF capability, not just IR (although it might have both).
Here's how to know for sure that what you're buying is the right thing. According to the HD FAQ page ( http://www.hunterdouglas.com/#!/freq...sked-questions )
The Platinum App is compatible with the following PowerRise 2.1 or PowerGlide 2.1 motorized products:
• Applause® Honeycomb Shades
• Duette® Honeycomb Shades (includes Top-Down, Top-Down/Bottom-Up, Duolite, and Skylight configurations)
• Designer Roller shades
• Designer Screen shades
• Luminette® Privacy Sheers
• Luminette® Modern Draperies
• Nantucket™ window shadings
• Pirouette® window shadings
• Silhouette® window shadings
• Skyline® Gliding Window Panels
• Vignette® Modern Roman Shades (Traditional™, Tailored™ and Tiered™ styles)
post #124 of 133 Old 12-30-2014, 07:48 PM
schwark1's Avatar
for anyone that is interested in controlling their hunter douglas platinum gateway from their Mac via an Alfred workflow..
https://github.com/schwark/alfred-hunterdouglas
inspired by code that tannewt had posted earlier in this thread. controls windows, rooms or scenes.
schwark1 is offline
post #125 of 133 Old 04-06-2015, 08:53 PM
Epacy's Avatar
Anyone have any other updates on HD integration into Smart Things or any other automation?
I see Smart Things is integrating Somfy (Timber shades) with their V2 controller.
Panny 65VT50 // Elite SC-67 // Paradigm Millenia  // Paradigm Seismic 12 // Belkin PF60 // Popcorn Hour // Harmony 890
Epacy is offline
post #126 of 133 Old 05-17-2015, 09:54 AM
batlin27's Avatar
Quoted: 45 Post(s)
I know this is an old thread but it shows fairly recent activity.
I just got 5 of these for my Master Bedroom. First off I was very unhappy to hear that you would only control 4 of them independently and that I would have to link up 2+ shades to be able to control them all via the remote (this seems to be different with the app but still annoying)
When they work they are great, but they seem to be VERY flaky. Sometimes only 2 of the 5 will get the signal through both the remote OR the Bridge kit, sometimes all of them will work, sometimes only 4 of them will work and sometimes they doesn't get the signal at all. I just got these a few days ago and we very excited but they seem to be way to flaky. Anyone else have this sort of experience?
batlin27 is offline
post #127 of 133 Old 05-17-2015, 12:08 PM
Quoted: 51 Post(s)
Liked: 7
Yes.
As part of integration I made a code change to repeat the last command after about 5 seconds - and that fixed the problem for me when shades are integrated into a larger system.
Now it is flaky only when the network layer on the HD bridge goes haywire, which happens more often than I would like...
notek is offline
post #128 of 133 Old 05-18-2015, 08:52 AM
humbug2's Avatar
Quoted: 48 Post(s)
I have 3 older Duettes powered by transformers and controlled by a wall switch. I have had several problems over the years which have been due to the insubstantial wiring and connections. I have resorted to bits of tape and cut and splice.
They are not suitable for anywhere you cannot get to them for repairs or for any application where dependable service is needed.
"Most people would die sooner than think, in fact they do so."  Bertrand Russell The ABC of Relativity, 1925
humbug2 is offline
post #129 of 133 Old 05-18-2015, 03:07 PM
batlin27's Avatar
Quoted: 45 Post(s)
Originally Posted by notek View Post
Yes.
When you say integrated what do you mean? How do you do this?
batlin27 is offline
post #130 of 133 Old 05-18-2015, 03:08 PM
batlin27's Avatar
Quoted: 45 Post(s)
These are the battery ones. Lucky they are in a location that is easily acessable I am just annoyed that they work about 50% of the time the way I want them to Bad thing about blinds is they are non refundable since they are "custom" to the windows
batlin27 is offline
post #131 of 133 Old 05-19-2015, 06:35 AM
Quoted: 51 Post(s)
Liked: 7
Custom integration with RadioRA 2 system - HD shades are tied into RA2 morning/evening scenes, as well as into keypad buttons. You do this by writing a component which listens to events in RA2 and converts those to HD bridge commands, and you install it on any available server you have.
notek is offline
post #132 of 133 Old 08-13-2015, 03:22 AM
wkearney99's Avatar
Quoted: 346 Post(s)
Liked: 132
I've got some of the new PowerView blinds. Not sure what to think yet, so I posted about it here.
wkearney99 is offline
post #133 of 133 Old 03-06-2016, 11:40 AM
Jasonn B's Avatar
Quoted: 381 Post(s)
Liked: 151
Another issue. Regarding 1.0 powerrise duette honeycombo. Per this instructions....
1) Shade has no power - Replace the batteries. Check the battery tube for any cracks and make sure the tube is firmly seated in the contacts.
2) Motor is burned out - Replace the motor
3) IR Eye board is burned out - Replace IR-Eye Board
4) Lift Limit Switch - Broken/Faulty, Needs adjusted or lift cord is not in front of metal switch arm. Limit Switch Troubleshooting
5) Reset Shade Limits - Lower Shade completely. If the motor is not responding then you may have to slip motor out of Lift-Cord-Shaft to dis-engage then lower shade fully then re-engage motor into Lift-Cord-Shaft. Once shade is fully lowered, point the remote controller at the IR-Eye in Headrail or Satelite eye and press the Down button (on the remote controller) for 5+ seconds then hit the up button. If the shade does not respond then see steps 1-4 above.
I think I need to do step #5. Do you have any idea on how to remote that little motor out of the lift cord shaft?
Shade was fine, but batteries died 6 months ago (shade is halfway down), and I didn't try replacing batteries until yesterday. After I put new batteries in, you can hear the motor try to go, and then it instantly stops, because I think it thinks it's in the full top position, but it's not. And I can't reset by holding down the down arrow on remote, because the shade isn't fully DOWN, which it said it's needs to be down to reset it.. Thanks!
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
Reply Home Automation
