Anyone heard of Woods Wireless Outlets sold at Lowes? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-16-2007, 08:56 AM - Thread Starter
suitcase's Avatar
I saw this in this weeks Lowes add:
http://lowes.shoplocal.com/lowes/def...lowes-071121-2
Its a great price, but I can't get any information on whether they're IR or RF. I'd appreciate any information any of you might have.
suitcase is offline
post #2 of 17 Old 11-16-2007, 08:58 AM
UHD Addict
aaronwt's Avatar
Quoted: 6050 Post(s)
Liked: 3750
You would think they would be RF, otherwise they would be very restrictive for use with a remote.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #3 of 17 Old 11-16-2007, 11:10 AM - Thread Starter
suitcase's Avatar
I tend to agree, but the price seems a little low for RF.
suitcase is offline
post #4 of 17 Old 11-21-2007, 08:49 PM
longtimelurker's Avatar
Quoted: 13 Post(s)
uhhh, maybe the ir rx "eye" on the units are a clue?
but what does it mean.
longtimelurker is offline
post #5 of 17 Old 11-30-2007, 05:03 AM
BA1320's Avatar
These units are rf. I bought it to use on a sub woofer that is behind my sofa works great. Cant beat it for $19.95
BA1320 is offline
post #6 of 17 Old 11-30-2007, 05:45 AM
video321's Avatar
Quoted: 21 Post(s)
These aren't available by me in NJ.
Wouldn't make a difference anyway since I actually wanted IR to be controlled by my dist. system.
video321 is offline
post #7 of 17 Old 11-30-2007, 06:03 AM
Ergoguy34's Avatar
For what its worth, Woods is one or the countries largest mfg of ext cords etc. The quality is usually very good..
200 +++ BD discs and counting...still enjoying 60+ HD-DVD's too!!
Ergoguy34 is offline
post #8 of 17 Old 12-04-2007, 04:29 AM
salanstur's Avatar
where can you get them Lowes is all out and no longer carries them?
salanstur is offline
post #9 of 17 Old 12-13-2007, 01:48 PM
dmullene's Avatar
I bought these but can't make them work. Any idea how to reprogram them to accept the controller's signal? All I get is the outlet units flashing red at me!
Tried their web site for any info but product is note even listed... Worse to call them; endless voicemail loops. If you can walk me thru the set up it would be greatly appreciated!
Ciao, Dan
dmullene is offline
post #10 of 17 Old 12-18-2007, 03:29 PM
JohnA51's Avatar
I too bought these at Loews...and used them for christmas tree controls...works sometimes, doesn't others...only could get two of the three receivers to accept the programming...very undependable...
JohnA51 is offline
post #11 of 17 Old 05-21-2008, 07:44 PM
unavol's Avatar
Quoted: 44 Post(s)
Liked: 51
Ciao, Dan
I'm having the same issue. I did find them under the Canadian products on their website. There is a pdf with instructions on how to program, but I can't make it work. I sent an e-mail asking for help. We'll see how it goes.
unavol
There's nothing to see here.
unavol is offline
post #12 of 17 Old 05-22-2008, 08:24 AM
prettyplants's Avatar
Re-programing the remote after power outage , battery change or other.
Be sure batteries are fresh and inserted properly. Plug a receiver into an outlet and the red light will flash. Push the "on" button of the remote. The light should stop flashing and is tuned to the number of the on button pushed(1,2 or3).
Repeat with the others. You can program each receiver to work on the same button by using it each time to program a receiver.
prettyplants is offline
post #13 of 17 Old 05-22-2008, 10:49 AM
unavol's Avatar
Quoted: 44 Post(s)
Liked: 51
Mine just stopped working. No power outage, etc. I've tried the reprogramming steps and I know the battery is in properly b/c it used to work. I guess the battey could be low, but I assumed it was OK b/c the light on the remote flashes when I push the button. Is there anything else that can be done?
ps-A new battery fixed the problem. Thanks!
unavol
unavol is offline
post #14 of 17 Old 06-13-2008, 11:36 PM
swotime's Avatar
This is caused by the battery being low. I had the same issue and just replaced my battery. Works like a charm now.
swotime is offline
post #15 of 17 Old 06-13-2008, 11:43 PM
swotime's Avatar
One other note... the new battery (Duracell) I used does not get in contact with the + (positive) end because the tip is not as long as the original battery that came with the remote. I had to use a small flathead screwdriver to pry it out a little so contact can be made on the + (positive end). So if you put the new battery in and do not see the light flashing when you press the ON button, it's not because of the battery. The battery I used is the 21/23 (MN21/A23). Hope this helps.
swotime is offline
post #16 of 17 Old 12-04-2013, 01:27 PM
lyn50's Avatar
DON'T WASTE YOUR MONEY
I BOUGHT ONE TO HAVE ON HAND LAST YEAR
THIS YEAR, TRIED IT OUT WITH MY CHRISTMAS LIGHTS; NEVER WORKED. THOUGHT IT MIGHT BE THE BATTERY SO REPLACED THAT. STILL WON'T WORK. TRIED TO FIND CONSUMER SERVICE AND WHAT A JOKE. BUY A DIFFERENT BRAND OTHER THAN WOODS
lyn50 is offline
post #17 of 17 Old 12-06-2013, 11:17 AM
unavol's Avatar
Quoted: 44 Post(s)
Liked: 51
I'm still using the ones I got over 5 years ago every day. I had a battery go bad in the remote, but that's the only issue I've had in 5 years. That's not bad for $20.
unavol
unavol is offline
Reply Home Automation
