Lutron PC control interface - AVS Forum | Home Theater Discussions And Reviews
Old 02-05-2008, 12:49 AM - Thread Starter
mani's Avatar
Quoted: 14 Post(s)
Does Lutron come with PC based control interface- Radio RA or grafik eye- or do you have to use 3 rd party software
thanks
mani
mani is offline
Old 02-05-2008, 08:46 PM
smoothtlk's Avatar
Both RadioRA and GrafikEye are PC compatible. I don't believe Lutron has their own control software, but you never know. MainLobby supports RadioRA and there is a 3rd party driver for the GrafikEye. One of our dealers wrote it.
CEO
Allonis LLC
smoothtlk is offline
Old 02-06-2008, 09:44 AM
emillika's Avatar
CQC also has a driver for the rs232 interface.
emillika is offline
Old 02-06-2008, 02:36 PM
IVB
IVB's Avatar
The Lutron RadioRA Components page shows a Network Control Interface with the following to say:
The RadioRA Network Control Interface allows control of a RadioRA system through a web browser (Internet Explorer, Netscape Navigator, Microsoft Windows XP Media Center, etc...)
Can be used on any RadioRA job with a Chronos System Bridge or RS232 Interface and a home network
Control light through a number of popular devices devices (PC, PDA, tablet, touch-screen) or remotely
Allows control of up to 8 User pages and up to 15 scenes
Model Number: RA-NET-120
Yes, I'm "that" Home Automation Guy.
IVB is offline
Old 05-08-2012, 01:05 PM
Blake745's Avatar
Does anyone have the software they can send me for the nci interface? It looks like I made the mistake of clicking auto upgrade in the advanced menu of the system. It wiped out the old file and tried to update it from a defunct in2nets web page. It looks like in2nets are out of business and as a result no file can be found. Pls help.
Blake745 is offline
Old 05-08-2012, 01:27 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Looks like the NCI serves it's own configuration web page.
http://resi.lutron.com/LinkClick.asp...id=217&mid=679
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
