Iphone 3Gs Receiver Hook Up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-31-2009, 01:16 PM - Thread Starter
eiger's Avatar
Quoted: 12 Post(s)
I'm looking to hook up my 3GS to my receiver and play music through my HT.
Open to both docking station and just a simple cable to run directly to receiver.
What are my options?
eiger is offline
post #2 of 9 Old 07-31-2009, 07:47 PM
oztech's Avatar
Liked: 101
oztech is offline
post #3 of 9 Old 08-01-2009, 09:53 AM - Thread Starter
eiger's Avatar
Quoted: 12 Post(s)
Originally Posted by oztech View Post
Something like this perhaps. http://store.apple.com/us/product/MB...mco=MjE0NjMxOQ
Nice find, thanks! Can't tell if it comes in black or not...
eiger is offline
post #4 of 9 Old 08-02-2009, 06:14 AM
UMass03's Avatar
You can also just use a stereo audio cable and skip the dock and it will work just fine, unless you are going for the look of the dock as well.
Xbox Live GamerTag: SpectreOne3
UMass03 is offline
post #5 of 9 Old 09-18-2009, 01:57 PM
geminigod's Avatar
umass03's statement is incorrect. A generic stereo audio cable didn't work with the 1st gen. iPhone and I am pretty certain that hasn't changed with the 3G and 3GS. Make sure it advertises compatibility with your iphone before purchasing. It requires a special cable for the iphone. Furthermore, if connecting to a decent receiver you are going to want to connect via the digital docking connection anyway for sound integrity purposes.
geminigod is offline
post #6 of 9 Old 09-27-2009, 07:08 AM
UMass03's Avatar
I can tell you from personal experience that it does work as that is how I have my 3G hooked up to my receiver.
UMass03 is offline
post #7 of 9 Old 10-23-2009, 05:48 PM
patnshan's Avatar
Location: close to Milwaukee, WI but far enough from the hood!
It does work, but the input level is very low requiring you to crank the sound on the unit increasing the distortion. The proper way is to get a dock with an AV out.
Pat
patnshan is offline
post #8 of 9 Old 10-23-2009, 06:34 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
I believe the 3GS has stereo bluetooth and therefore GO WIRELESS?
MrBobb is offline
post #9 of 9 Old 06-05-2010, 09:39 AM
rudolpht's Avatar
It does, but what do you use for a Bluetooth receiver to a standard receiver? I know some of the receivers today have it, but I need something cheaper than the Chordette at $900 to get the Bluetooth into a standard receiver.
Any ideas?
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
Reply Portable A/V
