How can one adjust the equalizer on a mp3 player to get optimal audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-11-2010, 09:19 PM - Thread Starter
jerrycomo's Avatar
I see 0.4, 1.0, 2.5, 6.3, 16 kHz on mine. There are also pre-settings.
I really don't have any musical ear.
Any way to "calibrate" the audio for best sound possible?
jerrycomo is offline
post #2 of 6 Old 04-13-2010, 05:33 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Play with the controls until it sounds the best to you!!
There is no perfect formula for everyone.
RCbridge is offline
post #3 of 6 Old 04-13-2010, 05:56 AM - Thread Starter
jerrycomo's Avatar
I guess I have no choice!
post #4 of 6 Old 04-13-2010, 10:50 AM
4Dthinker's Avatar
Your music will sound best with the EQ off or nuetral, and good headphones or an amp/speakers to play through. At best EQs are used to keep music from distorting a range of frequencies when playing through earbuds that can't handle them.
4Dthinker is offline
post #5 of 6 Old 04-14-2010, 08:20 PM
Digital Rules's Avatar
Quoted: 112 Post(s)
Liked: 24
Have you ever used the equalizer on a Sony, Cowon or Samsung? A high quality MP3 player can provide a richer listening experience through earphones if the EQ & other sound enhancements are adjusted correctly.(BBE, Clear Bass, Clear Stereo, Dynamic Normalizer . . . . Especially those hard to reproduce low frequencies through smaller earphones)
I do feel that the equalizer on an iPod is pretty much a waste of time once you listen to an MP3 player that is built with sound quality as a top priority.
Digital Rules is offline
post #6 of 6 Old 04-14-2010, 08:41 PM
Quoted: 112 Post(s)
Liked: 24
Sounds like you have a Sony? It all depends on which model you have & if you are using the supplied earphones.
I have the Sony NWZ-S639F & it sounds decent with the supplied earphones. I do like to increase the "Clear Bass" setting when I am outside or on the bus to enhance the lower frequencies that get lost in noisy environments. I don't particularly care for any of the presets.
Reply Portable A/V
