Bluetooth headset + laptop + phone - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2010, 12:26 PM - Thread Starter
DavidVTHokie's Avatar
I am a blueteeth noob and have a simple question before I buy a bt headset.
If I have a bluetooth headset and laptop and am streaming my Pandora AND then my blackberry rings (also bluetooth)
what happens?
Can I mate the headset to both at the same time and answer the phone and then go back to the music after the call?
-DavidVTHokie
DavidVTHokie is offline
post #2 of 2 Old 10-06-2010, 07:10 PM
oztech's Avatar
Liked: 101
You will have to look at your specs but there are several headset mfg's that can be paired
with several devices BluAnt I believe gives an audible when it changes devices there are
several others such as Jabra and I believe Motorola has one.
oztech is offline
Reply Portable A/V
