Looking for a player that takes svideo/composite input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-21-2011, 05:15 PM - Thread Starter
joebobfrank's Avatar
Hi,
What I'm looking for is basically just a portable screen that takes in SD video signals, namely sVideo or Composite video.
Ideal requirements:
5-8 inch screen (diagonal)
Displays composite or Svideo input
External power source
Minimal power consumption (<2 watts would be good, the lower the better)
Screen resolution does not really matter
Does not need any internal storage/playback
I'm hoping the is the right place to ask; if not, any suggestions on where I could ask around?
In case you're wondering, this screen will be used to display a live camera feed on a solar powered robot, hence the low power requirements.
Any help finding something like this will be greatly appreciated.
joebobfrank is offline
Reply Portable A/V
