Airport express vs Monoprice bluetooth receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-24-2011, 09:59 PM - Thread Starter
Gavin2010's Avatar
I'm looking for a way to power my indoor receiver from out around my pool with a wireless device. I hear people using airport express and apple tv but they are expensive. Has anyone tried http://www.monoprice.com/products/pr...seq=1&format=2
The reviews say the monoprice works 20-30ft, but audio may be a little degrading compared to just plugging device straight in. The monoprice device is $20 and apple products are $99. Apple tv may be a waste since the device I need will just be plugged into a 2 channel Harman Kardon Receiver for streaming pandora.
Any suggestions?
thanks
Gavin2010 is offline
post #2 of 4 Old 09-26-2011, 07:14 PM
ccotenj's Avatar
Liked: 101
2 completely different products...
i have my doubts that a bluetooth device would come anywhere near it's claimed range once you don't have los...
whereas the 2 apple products in question are wi-fi devices, and you can expect to get whatever range your wireless network will provide...
if youmlook,around a bit, you can likely find a used ax for less than 50 bucks...
- chris
ccotenj is offline
post #3 of 4 Old 09-29-2011, 12:25 AM
jaddie's Avatar
Quoted: 1295 Post(s)
Liked: 749
One vote here for Airport Express. Much better and easier to use than the BT solution. You can get them for $69 if you look around. Get several, you can pump iTunes into all of the at once, in sync. Distributed audio the easy way. In iTunes you get a little control panel with independent volume controls for each Airport, and a master for everything. Nice. They also will drive optical/digital into a DAC if you want something more high-end down the road. Nice little WiFi extender too.
Apple TV is nice too, but more of a pain if you don't use the video feature. I've got two Airports, one Apple TV second gen. Love then all, and sometimes run them all at once!
jaddie is offline
post #4 of 4 Old 12-23-2014, 11:22 AM
Liked: 1
i like the nyrius. works well, up to 30 ft... but after that... no dice.
shamu1023 is offline
Reply Portable A/V
