Any tablet able to play M2TS or MKV files? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-21-2012, 05:33 AM - Thread Starter
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
I've been Googling and searching this forum for this information, but I haven't been able to find an answer to this.
I am interested in buying two tables, but I was wondering if any of the tablets out there can play M2TS and or MKV files?
GusGus748s is offline
post #2 of 9 Old 03-31-2012, 07:24 AM
Falling2Pieces's Avatar
I would not know the answer to your question too but I can offer to you suggestions on how to go about finding the right tablet/s. That would be --- what are the requirements in order to play what you want to play? Only then can you determine which is the best.
Falling2Pieces is offline
post #3 of 9 Old 04-05-2012, 05:58 AM
Patch22's Avatar
What operating system are they running? Usually the ability to play types of media files is a software issue as opposed to hardware. There are a variety of media players available that can play both those file types, VLC for example, as long as there are not extenuating circumstances (ie trying to play 1080p movies on low end hardware)
Patch22 is offline
post #4 of 9 Old 04-05-2012, 06:14 AM - Thread Starter
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
I've got all of my media on an Unraid server. I am going to try to play around with Plex Media Server from my W7 PC, and try to stream the movies to another device and see how that works before I star buying tablets.
post #5 of 9 Old 04-24-2012, 07:39 AM
Arslanx's Avatar
Any tablet can play mkv video. But it depends by CPU (720p/1080p) and installed video player.
Arslanx is offline
post #6 of 9 Old 07-01-2012, 05:18 PM
DanPackMan's Avatar
Quoted: 299 Post(s)
Liked: 585
My Transformer TF101 plays 720P just fine, sometimes chokes on 1080P. Since tablets are wireless, you may find that you have problems streaming 1080P, it can be a problem no matter what device you use. If you are going to store the file on the tablet, you won't fit too much 1080 on it at one time due to file size.
So,, I'd plan on primarily sticking with 720P or less content.
MX video player is a free app that plays most file types. I've played some MKVs with no problems.
DanPackMan is offline
post #7 of 9 Old 07-01-2012, 06:43 PM - Thread Starter
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
I'm thinking of getting two IPADS and using Airplay to transcode video.
post #8 of 9 Old 08-01-2012, 09:14 AM
bwise863's Avatar
I have an iPad and have installed Plex. I run the Plex media server on a mac mini which is tied to my drobo for storage. I can stream/play m2ts and mkv and nearly any other video format.
Give that a look.
bwise863 is offline
post #9 of 9 Old 08-01-2012, 10:31 AM - Thread Starter
GusGus748s's Avatar
Quoted: 427 Post(s)
Liked: 705
Give that a look.
I was trying to find out if it is possible to pay without transcoding, but this isn't possible. I've used Plex before as well. Thanks.
Reply Portable A/V
