Need TV Wall Mount that I can lift the TV off to move it. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-19-2013, 04:43 PM - Thread Starter
historysleuth's Avatar
I need a TV wall mount that can:
1. Go out at least 15 inches from the wall to allow a 90 degree angle, because the 'audience' will often be sitting facing parallel to the mounting wall.
2. Be sturdy on the wall stud, but allow the TV to be lifted off the wall mount (OK if the arms come along, folded up), because sometimes I want to set the TV on its stand on a table for a larger viewing audience. I just don't want my Victorian living room to suffer an all the time techno-invasion.)
The TV is a Samsung 32in flatscreen Series C5 5000 with holes in a 200mm square.
I guess my other question is that, when a product says the holes are 8in, are they really Ok with 200mm?
historysleuth is offline
post #2 of 5 Old 02-20-2013, 01:54 AM
Colm's Avatar
Liked: 94
Originally Posted by historysleuth View Post
...15 inches from the wall...90 degree...
No problem. Plenty of choices.
...allow the TV to be lifted off the wall mount...
Pick one where you mount backets to the TV, then attach the brackets to the arm and secure with a set screw.
...when a product says the holes are 8in, are they really Ok with 200mm?
You decide. 200mm is about 1/8" less than 8".
Colm is offline
post #3 of 5 Old 02-20-2013, 08:14 AM
JoJho's Avatar
I'm not sure if it will help you or not. But at least I'd recommend you have a look at this.
http://tv-wall-mount.blogspot.com/2013/02/tv-wall-mount-types.html
JoJho is offline
post #4 of 5 Old 02-20-2013, 08:06 PM - Thread Starter
Hi Colm,
"...allow the TV to be lifted off the wall mount...
Pick one where you mount backets to the TV, then attach the brackets to the arm and secure with a set screw."
But then when I want to take the TV down off the wall to set it on a stand in the other room, won't I have to hold the TV (support its weight while I unscrew it from the plate)? I am sure I physically cannot do that. Maybe I am not picturing what you are saying.
post #5 of 5 Old 02-20-2013, 11:09 PM
Colm's Avatar
Liked: 94
Look at page 4 here.
Colm is offline
Reply Portable A/V
