iphone 5 lightning dongle? - AVS Forum | Home Theater Discussions And Reviews
Old 10-19-2013, 07:44 AM - Thread Starter
dweltman's Avatar
So my daughter would like to get a small stereo, using her iPhone 5 as the source. I figured she would be better off with a pair of speakers rather than a higher quality Bluetooth/airplay speaker like the Klipsch. I was thinking either the Audioengine or Nuforce, but the wireless dongles use the old connector. I imagine you could use the Lightning to 30-pin adapter, but I was wondering if there are any Lightning dongles out there? Any other solution people use? Also, has anyone been able to directly compare the Nuforce and Audioengine systems?
Thanks for your help.
dweltman is offline
