Date Recorded for Camcorder Clips - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-25-2014, 06:10 PM - Thread Starter
steveromo's Avatar
I have a JVC GZEX355 Camcorder. I have a few questions I have about importing / sorting the clips. 1. When I import clips (via data cable & SD card-to-USB port adapter) the folder I move them to will not display the "Date Taken/Modified/ etc" in the folder. The info is imbedded in the clip - I can see it when hovering the mouse or looking at it's properties - but it will not display in the folder. This would aid greatly when organizing / editing. 2. The camcorder default-labels each clip with a number, but there is no discerning those from the internal memory and the SD card. So many clips wind up with the same number. Any way to change this setting? and 3. The camcorder shows clips as thumbnails in the viewfinder, but not by clip number (I don't know how to find the clip number while looking via the camcorder.) If I could see clip number in the camcorder screen then deleting the un-needed clips would be much easier. Thanks for any replies!
steveromo is offline
Reply Portable A/V
