Are there any bluetooth speakers that will allow you to connect multiple speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-14-2016, 09:57 AM - Thread Starter
pawn3d's Avatar
I'm looking for something like these: http://www.samsclub.com/sams/40w-ind...rod17690030.ip I bought a pair of them from Sam's Club and they say you can connect up to 8 speakers. They're awesome, but for some reason, they were discontinued before they ever hit the stores.
pawn3d is offline
post #2 of 5 Old 02-14-2016, 07:06 PM
DanPackMan's Avatar
Quoted: 299 Post(s)
Liked: 604
Looks like you can still get them on Amazon, along with other models that look compatible.
http://www.amazon.com/Monster-Wirele.../dp/B0106HXV52
DanPackMan is offline
post #3 of 5 Old 04-07-2017, 11:51 AM
BiGx5MurF's Avatar
Quoted: 16 Post(s)
Liked: 1
I was looking for such a solution as well for my wife's salon. I ended up just getting a bunch of chromecast audios, and hooking them up to 2.1 pc speakers (swan m10, beautiful and good sounding budget speakers), and putting one in each room. Set them all up on the same wifi network, create a group that includes all of them, and you can stream pandora or anything else too all of them with a simple click.
BiGx5MurF is offline
post #4 of 5 Old 05-15-2017, 01:56 PM
njscalzi's Avatar
Liked: 1
Look into the UE(Ultimate Ears) line of bluetooth speakers. If you buy the same model such as the BOOM2 or MEGABOOM you can connect up to 150 of them!
njscalzi is offline
post #5 of 5 Old 07-04-2017, 01:32 PM
MIX_MASTER_ICE's Avatar
Quoted: 1427 Post(s)
Liked: 1204
JBL portable bluetooth speakers let you connect multiple speakers together. The new models coming out with Connect+ let you connect over 100 speakers to the same source.
Rec Room>Vivitek 1080p projector w/100" screen/Hisense 65" 4K, Onkyo TXNR656, Fluance signature towers & center, AV5 sides, Loft 40 rears, RBH I-12/e x2, I-12 x2 subs. Living Room>Sammy 59" Plasma, Onkyo HTRC560, Klipsch KF28 L/R, KC25 center, Polk RC60i in-wall rears, SVS PB12NSD (x2) subs. PC set up> 27" LG IPS, Onkyo TXNR509, Primus P363's, JBL 550P sub. Master Bedroom>Samsung 42" LED, Pioneer VSX532, Denon 5 spkr set, Jamo J110 sub. Gaming> PS4 (x2), PS3, XBox One (x2), XBox 360
MIX_MASTER_ICE is offline
Reply Portable A/V
