Which has best fidelity? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-20-2006, 10:26 PM - Thread Starter
kw3rd's Avatar
I'M looking to upgrade from my old 20gb ipod and I seems to overwhelmed with choices.
Does one brand have an edge over another in terms of audio quality?
I would imagine audiophiles would of embraced a particular brand, or have helped one gain a reputation.
Has a consensus been made yet?
kw3rd is offline
post #2 of 9 Old 12-05-2006, 08:55 AM
keithaxis's Avatar
i just bougth the 80 gig ipod and am converting everything to the "lossless" format...sounds very nice...
keithaxis is offline
post #3 of 9 Old 12-05-2006, 06:11 PM
oztech's Avatar
Liked: 101
30gig ipod all in lossless with ultimate ears super fi 5 pro earbuds
oztech is offline
post #4 of 9 Old 01-04-2007, 07:49 PM
talbain's Avatar
i agree. a 30 or 80 gig ipod + apple lossless = audio heaven...
---Mr. Met---
J-E-T-S-JETS JETS JETS!!!!!!! --- LETS GO DE-VILS!!!!!!! --- LETS GO METS!!!!!!! --- LETS GO NETS!!!!!!!
talbain is offline
post #5 of 9 Old 01-05-2007, 09:48 AM
jerkin's Avatar
How does lossless work? Do you just download it from apple and convert mp3s to it? I'll be getting my first ipod in a week or 2 and really don't know much about them.
jerkin is offline
post #6 of 9 Old 01-05-2007, 10:00 AM
keithaxis's Avatar
You cannot download lossless from Itunes. You would want to use real cd's to get your lossless on iPod...at least that is my way. The iTunes site already has compressed all music for sale to 128Kbps so that is not the way to go at it...
basically I have put 300 CD's on my 80 gig in lossless. Each song seems to run around 900 to 1000 Kbps and takes up about half the space a burned CD..
so 1000Kbps compared to 128Kbps makes all the difference for me. I can listen to that on my home system and it sounds about CD quality...
Keith
post #7 of 9 Old 01-24-2007, 05:51 PM
mike3411's Avatar
Are you encoding lossless mp3's for the Ipod to play, or are you using a different format? If it's mp3, what codec do you use?
I have all my lossless audio in .flac format, but I'm not sure if any portable music players support that.
mike3411 is offline
post #8 of 9 Old 01-24-2007, 06:36 PM
oztech's Avatar
Liked: 101
i am ripping my cd collection to lossless on the mac pro and sending it
to the ipod .
oztech is offline
post #9 of 9 Old 01-25-2007, 06:07 PM
Brown Radagast's Avatar
itunes also has a setting for lossless mp3s. Or, you could use Windows media player, which also has a lossless setting
Also, if you're getting a 30/80 gig vid ipod, you'll need either Mac or WinXP for itunes v7...one of the lesser thought of requirements, IMHO
MY DILEMMA: New car or PJ? New car or PJ? New car or PJ?
Brown Radagast is offline
Reply Portable A/V
