Zune Movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-16-2006, 10:31 PM - Thread Starter
MacZero's Avatar
I don't have a Zune yet, but am planning on getting one in the next few days, so I had some questions about videos on it from some experienced users. I know it supports WMV. I have the Ripit4me/DVD decrypter/DVD shrink combo to rip dvds, but when it rips it makes about a million little files. This isn't a big deal to view, since opening one runs the whole movie, but if I wanted to put it on a Zune, how would I do that, and would I need to convert the files any further?
MacZero is offline
post #2 of 5 Old 12-26-2006, 11:07 AM
darthrsg's Avatar
Location: Barrel of Burning Trash On A Cold Skid Row Street
Quoted: 2092 Post(s)
Liked: 2523
I think you can open the avi files in Windows Movie Maker and convert them to wmv. I bought Winavi and it does the trick.
darthrsg is offline
post #3 of 5 Old 01-02-2007, 08:16 PM
murphykevin413's Avatar
i'm using AoA DVD Ripper to convert the DVD into a WMV file.
MURPH
murphykevin413 is offline
post #4 of 5 Old 01-02-2007, 09:31 PM
Quikzilver's Avatar
I purchased CuCuSoft's DVD to Zune Converter Suite and it converts it straight to WMV, I don't even have to deal with all of those .vob files.
Hat Trick: XBOX 360, PS3, Wii
XBL GT: Osiriis
PSN GT: Poseidon44
Quikzilver is offline
post #5 of 5 Old 01-04-2007, 12:25 PM
homerx's Avatar
Well I use pinacle mobile media converter. It sells for 30 bucks at BB. I converts files to mpg4. It outputs them as PSP or IPod sized not sure if the zune can take those files and convert them. But it works flawlessly for ipod.
homerx is offline
Reply Portable A/V
