Creative ZEN V Plus Face Buttons - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-08-2007, 10:15 AM - Thread Starter
Quoted: 18 Post(s)
I recently bought my first MP3 player, an 8 GB Creative ZEN V Plus and am very happy with its feature set for my needs.
It arrived today and I've just taken it out of the box to check it out and noticed a difference between the Play/Pause button and the Back button. The Play/Pause button has a nice positive click feel to it when pressed, whereas the Back one feels a little spongy and doesn't give any feedback like Play/Pause, it's difficult to tell you've even pressed it although I can see it moving up and down slightly when you look at it from the side.
To all V and V Plus owners, is this normal for them to feel different or do both of yours have a slight positive click to them when pressed?
mjpartyboy is offline
post #2 of 4 Old 02-08-2007, 11:05 AM
Milner's Avatar
I don't have a 5, but you can probably find an answer here
http://www.epizenter.net/e107_plugins/forum/forum.php
Yep, I am a newbie, don't listen to me, don't do what I do, just ignore me, but I won't go away.
Milner is offline
post #3 of 4 Old 02-10-2007, 01:22 PM - Thread Starter
Quoted: 18 Post(s)
I heard back from Creative Tech Support:
With regards to your enquiry, the buttons were designed as it is. Unless they are not working properly, else it is fine.
post #4 of 4 Old 02-27-2007, 04:28 AM - Thread Starter
Quoted: 18 Post(s)
After using my V Plus for a couple of weeks now the back button seems to have loosened and feels better than it first did.
Reply Portable A/V
