Archos 704 WiFi One users opinion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-13-2007, 10:13 PM - Thread Starter
eddiscus's Avatar
I have been using the 704 for about 1 week now after purchase and am overall satisfied with its performance. I figured I would share may experiences with it so far.
I will start with the good.
1: The screen size 800 X 480 7" diagonal would not watch video on a screen any smaller. So far I have left the screen mode in auto, it does not distort the video at least what I can see from a viewing distance of 1-2 feet.
2: Connectivity to a media center PC. I first connected it to my media center PC running the latest version of windows media player. The Archos player then prompted if I wanted to connect in media player or hard drive mode ( i selected media player mode). It proceeded to down load all my music files and pictures from the mediac enter PC to the Archos player. It then proceeded to convert and down load 3 shows each from 2 different series and one other show that was in my recorded TV folder on the media center PC. I let this run over night as each conversion of a 1 hour show tool slightly longer than 1 hour itself.
3: Connection via wifi to my home network. Connection was straight forward and easily configured for a secure network. I use the wifi connection to transfer converted DVD and recorded shows to the Archos while it sits in the DVR docking station. Also its Opera web browser work's well I was able to browse AVSforum with no problems.
4: Portability, about a little larger but thinner than a paperback and weighs 22 oz.
Sits well on the dash of my car when waiting for the wife to arrive at the bus station. Allows me to catch up on the shows she does not really like to sit through.
5: Touchscreen works well and is really cool.
Now the down side.
1: Converted video compatibility. The latest version of windows media player converted recorded TV to a playable format but you do not have the functionality of the Bookmark function or the Video drag bar that is at the bottom of the video playback screen allowing for FF through commercials. Archos has replied they are aware of this and are working on a fix and have notified Microsoft as well.
2: Converting recorded TV takes awhile. Converting a 1 hour recorded Media Center TV show at 720x480 resolution takes about 3 hours on a 3 year old dell workstation. Once converted copying to the Archos via wifi takes about 20 minutes. I have recently converted some recorded shows to a lower resolution but have not watched the shows on the archos.
3: DVR station, I have also added the DVR station to the mix. It does record programs as advertised but I have had some compatibility issues with IR control. After setting up the IR control using the archos player and testing it from the on screen test buttons it fails to change channels that are 3 numbers long consistently and accurately. I have not tried other codes listed for motorola brand cable boxes as of yet. Also when it starts a scheduled program it sends out a power on signal for the motorola box. Since I usually leave the box powered on it shuts the box off. For now I use the Motorola box guides reminder function to change the channel and the Archos scheduler to start and stop the Archos record function.
Overall opinion:
Minor bugs aside I really like the quality of the player, it combines all my CD recordings a good amount of my family photo's as well as recorded TV and converted DVD's with a 7" quality screen.
So far I like the following file conversion utilities:
http://www.avs4you.com/
eddiscus is offline
post #2 of 4 Old 05-19-2007, 04:47 PM
m. zillch's Avatar
Quoted: 1874 Post(s)
Liked: 1208
Thanks for you detailed report. That's outstanding resolution for a 7 inch LCD! I am curious if I could use this as a live video monitor for the component video out of an HD camcorder (or a DVD player/ HD cablebox). I guess using the docking station, can the 704 take in a live video signal in 480i/p, 720p, or 1080i (using a typical red, green, blue RCA component connection) and display it live to the screen? I don't care about recording the image, just viewing it. TIA.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #3 of 4 Old 05-20-2007, 10:01 AM - Thread Starter
eddiscus's Avatar
Sorry the best input connection on the dvr base is s-video. It does have component out I guess if you are playing a dvd file. I was disapointed as well to see no component input.
I guess we can thank the paranoid movie and cable industry, god forbid we be able to record anything in high quality.
eddiscus is offline
post #4 of 4 Old 09-28-2007, 01:06 AM
Vipfreak's Avatar
Quoted: 81 Post(s)
Liked: 83
I just got a 704 and so far I've loved it. So much better than my Philips iPod Portable Dvd player and iPod Video that I'll probably get rid of both. I'm gonna get the gen 5( or does it matter what gen?) travel adapter so I can do video input to play my 360 at work.
oh geez... that was a big blow. Guess I won't be getting that. Is that for the gen 5 dvr too? I'm hoping I can use the remote with the micro key pad for when I'm online.
My Summer Motto: "When Nature turns off the damn heat I'll turn off my A/C"
Vipfreak is offline
Reply Portable A/V
