Ipod to TV? - AVS Forum
post #1 of 3 Old 05-14-2007, 08:38 AM - Thread Starter
whiskey alpha's Avatar
You'll have to excuse my ignorance, but my knowledge stops at home theater and I know nothing about the IPOD.
My father inlaw has one and wants to know if someone makes a cable to connect his IPOD to his TV so he can watch movies he has dowloaded? He has a new flat screen so either HMDI or Component is available. Thanks.
whiskey alpha is offline
post #2 of 3 Old 05-14-2007, 11:39 AM
jntaylor63's Avatar
You can just get a simple Ipod dock that has S-Video and audio out puts. Make sure to go with s-video as that's your best bet now. Monster Cable makes an AV cable that has S Video and Audio and plugs into the dock slot at the bottom. This option is cheaper, but you run off the Ipods battery.
jntaylor63 is offline
post #3 of 3 Old 05-14-2007, 01:36 PM
Vidmaven's Avatar
All you need is one of these (if you don't want to go the dock route):
iPod RCA AV Cable
You can pick one up at almost any electronics store.
The problem with obsessions is that they are insatiable.
Vidmaven is offline
Reply Portable A/V
