Mp3, Wma, Ogg, Etc>>>>>> - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-30-2007, 01:14 PM - Thread Starter
RayGuy's Avatar
Quoted: 994 Post(s)
Liked: 873
Going to get into some portable audio in the near future (Creative Zen?). Won't be Apple. What format should I use? I am looking for the best quality of sound, but it must be very simple to use. I am going to reproduce about 400 CDs that I own and put them on to the portable device.
What software should I use? What rate (64, 128, 256)? I assume that all of my classical will not transfer well enough to actually be enjoyed (is this true?).
As you can see I am a complete neophyte .. please lend your expertise!
RayGuy is offline
post #2 of 4 Old 09-12-2007, 07:47 AM
black_box's Avatar
For "best quality" sound you will want a lossless music format. This is probably more important for your intended listening (classical). Check this out for a good comparison:
http://www.bobulous.org.uk/misc/audioFormats.html
To get lossless on a portable player, you should look for one that plays either WAV, FLAC, or Monkey's Audio (that link mentions poor hardware support for this one, i think). Not mentioned in the article, but "lossless WMA" (microsoft) may also work. The other format i know of is apple's AAIC or something, but since you don't want an iPod thats out.
Take note of the file size for the formats in the above link. 500-800MB per CD will chew through a flash-based drive really quickly, so you might consider a hard drive based player. If you don't mind purchasing and swapping separate memory cards, some players have both a flash drive and also an expansion slot for up to 2GB cards. I think the SanDisk e260/e270/e280 series were the ones that had this.
you'll also need some good quality headphones, probably full ear enclosures for "best quality". however, if you'll be listening in a distracting environment, you may not notice all this attention paid to quality and maybe Mp3 encoding is an acceptable compromise (for much higher capacity).
black_box is offline
post #3 of 4 Old 09-22-2007, 06:39 PM
jongig's Avatar
Quoted: 17 Post(s)
More about lossless please.
I have all my media in WMA lossless and my Buffalo Linktheater won't play them. I ordered but have not received a Helios X-5000 and it plays lossless but I just learned it will play Flac but not WMA. I like using Windows Media player and it won't record to Flac.
If I decide to move my music to Flac from WMA how do I do it and what's the best way?
john
jongig is offline
post #4 of 4 Old 09-24-2007, 12:16 PM
black_box's Avatar
sorry i haven't done any converting. a google search turned up this:
www.foobar2000.org
or VUPlayer, DBPowerAmp, Winamp...
Reply Portable A/V
