iPod Shuffle Recognition Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-28-2007, 08:13 PM - Thread Starter
Hatman's Avatar
My iPod Shuffle (2nd generation) suddenly is not being recognized by either windows or iTunes. I hooked it up as I always do to recharge it and nothing. Nor will it charge. It just appears dead. I tried apple's iPod help website but that was a waste of time. Any help would be appreciated.
Hatman is offline
post #2 of 2 Old 12-01-2007, 06:13 AM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 134
There is a fix. It's called the "shuffle reset utility." I have a 1st Gen Shuffle and have successfully used the utility to restore my Shuffle to its original factory settings and then iTunes would recognize it again and all was well. I have not used the 2nd Gen reset utility, but I presume it works the same way.
http://docs.info.apple.com/article.html?artnum=305204
Good luck.
Will2007 is offline
Reply Portable A/V
