Two iPods, one computer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-19-2007, 01:34 PM - Thread Starter
Adult Beverage's Avatar
Quoted: 39 Post(s)
Liked: 27
My wife and daughter are getting iPods for Christmas. They'll be using iTunes on the same computer to download their music. Are there any problems maintaining separate libraries for each? Problems sync-ing them to their separate libraries?
Think ya used enough dynamite there, Butch?
Adult Beverage is offline
post #2 of 7 Old 12-19-2007, 02:17 PM
ccotenj's Avatar
Liked: 101
the "best/easiest" way to do this is to have one library, and then create separate playlists for each ipod and then set the ipods to sync to their chosen playlists.
this is the way we do it with 5 ipods, and it seems to work pretty well.
- chris
ccotenj is offline
post #3 of 7 Old 12-19-2007, 02:28 PM - Thread Starter
Quoted: 39 Post(s)
Liked: 27
Thanks. I have a followup question. If you buy a song, can it be in both playlists and on both ipods, or does it have to be purchased twice?
post #4 of 7 Old 12-19-2007, 04:28 PM
ccotenj's Avatar
Liked: 101
yes. no problem there, you don't need to purchase it twice.
- chris
ccotenj is offline
post #5 of 7 Old 12-21-2007, 01:09 PM
memnoch2's Avatar
i believe the apple macs support multiple libraries in itunes.
memnoch2 is offline
post #6 of 7 Old 12-21-2007, 04:05 PM
ccotenj's Avatar
Liked: 101
yes, there are ways to use multiple libraries (in windows too). however, the way i outlined is simpler. there's no "need" to use multiple libraries.
- chris
ccotenj is offline
post #7 of 7 Old 12-26-2007, 12:08 AM
talbain's Avatar
the only problem with this shared approach (that i've found) is that rating the songs become an issue with shared libraries. if that doesn't matter to you (though some people use them as the cornerstone of playlists), then it will work fine
---Mr. Met---
J-E-T-S-JETS JETS JETS!!!!!!! --- LETS GO DE-VILS!!!!!!! --- LETS GO METS!!!!!!! --- LETS GO NETS!!!!!!!
talbain is offline
Reply Portable A/V
