ARCHOS 605 WIFI - Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-23-2007, 07:43 AM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
I need help:
I've just bought a new Archos 605 WIFI, my Laptop can not recognize the Archos after I plug it in via USB, and click "USB enable" at Archos. What seem to be the problem?
THANKS
iwanrs is offline
post #2 of 4 Old 12-26-2007, 05:56 PM
w00dw00d's Avatar
After clicking enable usb what happens. Look in your file system to see if its loaded as an external drive.
What O/S are you using.
w00dw00d is offline
post #3 of 4 Old 12-27-2007, 01:50 AM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
My OS is Window XP, click my computer there is nothing show Archos or external device, unlike I use to connect my older Archos (405) and external Hard Drive, the Laptop recognize them in no time. It is really weird.
I've just bought my new Archos 605 Wifi from B&H Photo 3 weeks ago. Should be loaded with most recent firmware etc.
Can you tell me what else I should try/do.
iwanrs is offline
post #4 of 4 Old 12-28-2007, 09:01 PM
JeromeS's Avatar
Go into the Menu/Settings/System and see what your USB Preference is saying. If it isn't saying PC Hard Drive then switch it and see what happens. If you still need help, go to http://forum.archosfans.com
JeromeS is offline
Reply Portable A/V
