Official Samsung LNxxA650 Owner's Thread - Page 174 - AVS Forum | Home Theater Discussions And Reviews
post #5191 of 23557 Old 04-14-2008, 12:24 PM
RiVoLT's Avatar
Originally Posted by gilesmcgrath View Post
I believe it is, but it is not as high as 1003.G was. I am hoping to get it up to that level again, but I am not sure how to fix the SM.
For those that need to juice up AMP - FYI - I take no responsibility this is easy but it is at your own risk. Do not mess with settings that you are unsure of.
To increase AMP in the SM what you need to do is:
1. Turn off the TV
2. Press 'Mute' '1' '8' '2' 'Power'
3. The TV will start and you will be in the SM (give it a few extra seconds).
NOTICE: On this screen you will see an 'FRCM_Option' that is greyed out. ALSO take note of the 'View Log' option - you will need this in the end.
4. The first item is 'Optionbyte' go into that menu.
5. There will be an 'FRCM Option'
6. Click and set it to ON
7. Hit Return (maybe hit it 2x) to go back to the main menu
8. Now you will notice that the FRCM_Option is not greyed out.
9. Go into the 'FRCM_Option' menu
10. You will see Film_Low - Film_Medi - Film_High listed 4 times each. (SD or HD and 22 and 32)
11. To change say AMP 'High' setting change ALL FOUR Film_High options
12. Remember that '32' is off and '0' is full blast. I assume you are looking to make all four Film_High_?D_#2 options to '0' instead of 10 (default in 1003.M)
13. Once the changes are made hit return to go back to main menu.
14. Go back to OptionByte and turn off the 'FRCM Option'
15. Go back to the Main SM menu and you will see FRCM_Option greyed out again.
16. Go to the 'View Log' option and choose 'Delete Log'
17. Press the 'Right' corner of the 'wheel' on the remote or just right direction on another universal remote. The word 'OK' should appear to confirm that its deleted.
18. Go back and select 'View Log' instead of 'Delete Log' and it should say 'Log does not exist!!'
19. Now that you've 'covered your tracks'. You can hit 'Power' to turn off the tv and then turn it back on and magically your 'AMP' will be 'Juiced up'.
20. Enjoy!
PM if you have any other questions. Also please refer to my prior post if you want to see screens as reference.
RiVoLT is offline
post #5192 of 23557 Old 04-14-2008, 12:32 PM
Kineahora's Avatar
Originally Posted by RiVoLT View Post
For those that need to juice up AMP - FYI - I take no responsibility this is easy but it is at your own risk. Do not mess with settings that you are unsure of...
Awesome post. Thanks
ÂSK
Kineahora is offline
post #5193 of 23557 Old 04-14-2008, 12:53 PM
mikesj's Avatar
Can we post this in the first post of this thread ? so we don't get lost of this good info in the middle of thread
thanks,
Mike
mikesj is offline
post #5194 of 23557 Old 04-14-2008, 01:16 PM
tgyberg's Avatar
1. Turn off the TV
20. Enjoy!
Thanks again for these great posts!! Is it just as easy to go reverse these settings if one wants to change things back to stock? It would seem so but I just want to be sure!
tgyberg is offline
post #5195 of 23557 Old 04-14-2008, 01:48 PM
RiVoLT's Avatar
Yes exact same process - just OptionByte - enable FRCM - change your settings back to stock settings (incase you forget them - I kindly posted the screen caps of 'default' settings for all firmwares out so far ) - OptionByte - disable FRCM - Delete log - power off / on.
-RiVoLT
RiVoLT is offline
post #5196 of 23557 Old 04-14-2008, 02:22 PM
tomhayes's Avatar
I am seriously considering buying the 46A650. Right now I have a Sony KV-34XBR400 CRT, which has the best picture u have ever seen on a TV, but is smaller by 12 inches.
Anyone own the Samung that moved from a nice CRT? Was it worth it?
tomhayes is offline
post #5197 of 23557 Old 04-14-2008, 02:37 PM
ATC1's Avatar
I replaced my Sony 34" XBR CRT with the LN46A650. I too thought (and still do think) the Sony produced a fantastic HD picture. When you get the 46A650 setup, you will be amazed at the difference. Words like brilliance and stunning come to mind when describing the picture quality.
You will not be disappointed.
(and about 150 lbs. lighter than the Sony too )
ATC1 is offline
post #5198 of 23557 Old 04-14-2008, 02:51 PM
mitsu2k's Avatar
Anyone able to get a near delivery date on a 52" from Amazon lately or are they out of stock (even though they claim in stock)?
mitsu2k is offline
post #5199 of 23557 Old 04-14-2008, 02:53 PM
per4mer8's Avatar
I ordered mine on 4/11 and it shipped today through CEVA from Reno NV......I'm in Vegas so it shouldn't be more than a day or two for me.
per4mer8 is offline
post #5200 of 23557 Old 04-14-2008, 02:55 PM
sooner54's Avatar
Allright guys got my second 52inch dlp from BB yesterday. Returned first one due to flashlighting in both upper corners. Well' what do you know so does this one plus maybe some slight clouding in lower bottom. I have only ran this tv for 10 hours. Do I need to let a certain amount of hours to go by before backlight breaks in? On movie mode its not as badf but still bothersome to see lights in corners on dark scenes. I'm new to lcd technology. Should I just get used to seeing light??? Are there any 650 sets where in a total dark room you do not see lights in corners?? I was told some LCD sets were worse than others. Would you keep mine? Thanks and sorry for rambling!!
sooner54 is offline
post #5201 of 23557 Old 04-14-2008, 03:10 PM
socaler's Avatar
buydig price jumped from ~2700 to ~2900 today.
wonder if it'll drop back down anytime soon.
socaler is offline
post #5202 of 23557 Old 04-14-2008, 03:27 PM
Lice's Avatar
Same boat as you ATC! I had the same tv. You know, on most movies I think it looks great. But the CRT had a little more solid look to it. I cant describe it really, but it felt more natural. Planet earth on my old CRT was amazing. Every scene was just flawless. On the 650 its great, but it just doesn't hold up the same. for example the caves episode is terrible on the 650, almost looked like i was streaming it off youtube. The blacks looked like they where alive with blues and purples and squares moving in it.
Movies on the 650 are very impressive, much more wow than the crt. the 650's flesh tones and detail is amazing. Im glad I upgraded because the CRT was just to small for gaming and movies. The AMP is starting to grow on me but it slightly stutters on medium and looks distracting. On low it seems to be fine. Yes, it is also 150lbs lighter (Moving it up and down stairs twice made me loathe it.)
Lice is offline
post #5203 of 23557 Old 04-14-2008, 03:34 PM
Meparch's Avatar
I have some light clouding myself. For this very reason I am not sure if I want to exchange it, the next one may be worse. The clouding has decreased over the weekend, got it in thursday. Still going back on forth on what to do. It isn't perfect and for 3 grand it should be but it is livable. I would exchange it in a heart beat if I knew for sure the next one would be better.
Meparch is offline
post #5204 of 23557 Old 04-14-2008, 03:38 PM
BoNg420's Avatar
man samsung sucks. They are gonna send another technician out since the first guy was an *******. Since the guy suggested replacing the panel, they told me that is not cost effective, so they would setup an exchange upon another visit.
I got some weird discoloration, blacks look purplish/pinkish along the side bezel on both sides. Looks to come out about 3 inches on each side.
Also have a dead pixel.
What oh what should I do?
Finally got a good TV, my 9th TV. LN52A650 was exchanged by Samsung for free for a LN52A750! No problems as of now.
BoNg420 is offline
post #5205 of 23557 Old 04-14-2008, 04:35 PM
wtfer's Avatar
Quoted: 227 Post(s)
Liked: 57
This your 9th or 10th TV?
Maybe you should upgrade your sig
wtfer is offline
post #5206 of 23557 Old 04-14-2008, 04:49 PM
lipcrkr's Avatar
Originally Posted by CEB II View Post
Some vendors offer 24AWG without the braid (not sure about Monoprice), which takes care of most of the concern regarding bending the cables. You are correct, the braided 24AWG cables can be tough to fit if a sharp turn is needed in the installation. Everything has trade offs.
And there's always these:
http://www.engadgethd.com/2008/04/14...u-likely-dont/
lipcrkr is offline
post #5207 of 23557 Old 04-14-2008, 04:53 PM
lleka's Avatar
Can anyone tell me what page of this thread shows some settings (650).I know i saw some a couple of days ago but cant find it now.
lleka is offline
post #5208 of 23557 Old 04-14-2008, 05:20 PM
BoNg420's Avatar
8th...
BoNg420 is offline
post #5209 of 23557 Old 04-14-2008, 06:02 PM
kenlint's Avatar
I just got this TV last week (46 inch). Ive noticed that about every 10 minutes or so on average, the sound seems to "hiccup" or "skip". I have the cable box and xbox360 hooked up through component 1&2 respectively and have had the issue happen on both. I have checked all of the connections and switched through different sound modes...turned off and on the surround feature on the tv as well as the auto volume and I continue to hear the issue every so often. Has anyone else experienced this? Any help is much appreciated.
kenlint is offline
post #5210 of 23557 Old 04-14-2008, 06:13 PM
matt6's Avatar
Crap, last time I was on, page 72 was the last!
Has the random shut off/turn on been solved?
What other problems seem to be major?
I nearly convinced myself to order the 52 off Amazon last night, but I wanna be sure the issues are solved.
Also, anyone have experience returning a 52" to Amazon should something go wrong?
THANK YOU!
matt6 is offline
post #5211 of 23557 Old 04-14-2008, 06:22 PM
themistocles's Avatar
Well.... yeaah... I would say I do like that concept! lol How does that work? Will those lock on to all HDMI ports?
themistocles is offline
post #5212 of 23557 Old 04-14-2008, 06:30 PM
JJC23's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=1010609
JJC23 is offline
post #5213 of 23557 Old 04-14-2008, 06:46 PM
metal83's Avatar
8th...
Your catching up to melol.
metal83 is offline
post #5214 of 23557 Old 04-14-2008, 06:48 PM
metal83's Avatar
What does it sound like, is it just an audio drop out, or does it make like a popping/crackle type noise?
metal83 is offline
post #5215 of 23557 Old 04-14-2008, 06:49 PM
lipcrkr's Avatar
I think the concept is if they are securely locked it will negate any unnecessary movement which might result in an HDMI port being loosend. I just happened upon these as i visit Engadget every day and saw some posts mentioning HDMI cables.
lipcrkr is offline
post #5216 of 23557 Old 04-14-2008, 07:12 PM
Cynn's Avatar
1. Turn off the TV
20. Enjoy!
Does this increase stutter or TBE or any other bad stuff?
twitter.com/Cynnthetic
I own X360 - Wii - PS3
I see @ 1080p
I'm BROKE!
Cynn is offline
post #5217 of 23557 Old 04-14-2008, 07:16 PM
lipcrkr's Avatar
It increases the chance of voiding the warranty
lipcrkr is offline
post #5218 of 23557 Old 04-14-2008, 07:17 PM
loganharpdawg's Avatar
THANK YOU!
fixed with firmware 1003.M (download from samsung.com)
some have some sound issues
other than that, just your normal (should it be?) clouding, flashlighting, and other random defects (not effecting all sets)
loganharpdawg is offline
post #5219 of 23557 Old 04-14-2008, 07:20 PM
kenlint's Avatar
Thanks for the reply. Its weird, it doesnt make a popping or crackle noise. It almost sounds like a noise if you were switching between sound modes (if that makes any sense) but the style of the sound doesnt change, it just skips real quick. I guess you could call it an audio drop, its really quick....and annoying.
kenlint is offline
post #5220 of 23557 Old 04-14-2008, 07:34 PM
peking00's Avatar
Wow, how many of us had the Sony XBR CRT? I agree, it was an amazing TV for almost 10 years (for me), but to me it's two-dimensional... a phenomenal picture, but flat. My new 650 LCD seems three-dimensional. Maybe it sounds strange, but that's the only way I can explain it. It's like watching real life.
peking00 is offline
Reply LCD Flat Panel Displays
<<. , Lcd Hdtv , Samsung 19 Inch Lcd Hdtv Ln19a650 , Samsung 37 Inch Lcd Hdtv Ln37a550
