Official Samsung LNxxA650 Owner's Thread - Page 230 - AVS Forum | Home Theater Discussions And Reviews
post #6871 of 23552 Old 04-28-2008, 01:22 PM
diabolyte's Avatar
Originally Posted by STILESP113 View Post
what the hell do u mean?
the patients showed some patience in waiting for their doctor.
diabolyte is offline
post #6872 of 23552 Old 04-28-2008, 01:24 PM
Ready2Mosh's Avatar
Originally Posted by sd13 View Post
Ummm its not the cables. Since this is my 8th consecutive tv with at least one issue, i think i have become a troubleshooting expert by now. Its a DEFECT of the actual television.
Where are the strips, in the middle of the screen, the side, on top or somewhere else? Did you try 16 x 9 mode to see if it goes away?
Mosh~~
Ready2Mosh is offline
post #6873 of 23552 Old 04-28-2008, 01:28 PM
sd13's Avatar
Quoted: 29 Post(s)
Mosh~~
ive tried all modes and all inputs. They are vertical about one inch thick and they run from top to bottom. They are transparent and very noticeable on a solid background.
sd13 is offline
post #6874 of 23552 Old 04-28-2008, 01:28 PM
jazzbass's Avatar
This sounds more like delamination to me.
jazzbass is offline
post #6875 of 23552 Old 04-28-2008, 01:30 PM
nitt4ever's Avatar
Originally Posted by sharkcohen View Post
I had my laptop driving my 650 five minutes after the LCD was out of the box. I'm sure you'll be fine.
Did you have the laptop connected via DVI to HDMI, by chance? I tried to get it displayed on the TV under both Linux and Windows with no luck (so far). If you did, how did you do it? Thanks.
nitt4ever is offline
post #6876 of 23552 Old 04-28-2008, 01:35 PM
nitt4ever's Avatar
Here are some more gradiant pictures. And here is a site that has all sorts of color patterns in 1920 x 1080, so have at it.
http://images.google.com/imgres?imgu...%3D2%26hl%3Den
Mosh~~
Here is a link to even more patterns;
http://images.google.com/images?gbv=...=Search+Images
Ready2Mosh,
Thanks! Very much appreciated!
post #6877 of 23552 Old 04-28-2008, 01:37 PM
Ready2Mosh's Avatar
Originally Posted by nitt4ever View Post
Ready2Mosh,
No problem, anything to put peoples minds to rest. I know I want my TV to be all it should be, so having thoughs of negatives don't help any.
Mosh~~
post #6878 of 23552 Old 04-28-2008, 01:39 PM
stlgasman's Avatar
Originally Posted by taurus2007 View Post
Semi-gloss.
How will it do in a sunny room?
stlgasman is offline
post #6879 of 23552 Old 04-28-2008, 01:41 PM
sd13's Avatar
Quoted: 29 Post(s)
thats just effing great! I went from flicker, to stutter, to smearing, back to flicker, then to worse stutter, then to deteriorated PQ with even greater stutter, and finally now to "delamination". I requested an exchange from amazon, but im not optimistic at all. Im now trying to guess what the next issue will be. Purple haze is the odds on favorite for now, but banding is a close second.
sd13 is offline
post #6880 of 23552 Old 04-28-2008, 01:45 PM
taurus2007's Avatar
Are you sure you really want to go through all of those again? Why not just request a refund and go buy something else.
Go 24
taurus2007 is offline
post #6881 of 23552 Old 04-28-2008, 01:46 PM
taurus2007's Avatar
It depends on the angle of the lights coming in or hitting the bezel. Do you currently have a tv in the place that you plan to put the A650 there?
Go 24
post #6882 of 23552 Old 04-28-2008, 01:50 PM
ram48335's Avatar
Thanks for ur reply, if I do adjust the picture size for non-HD to wide fit then the HD also displays in wide, but I do not want to view the HD in wide and want to retain the 16:9. Is there anyway I can set once that allows to switch wide and 16:9 for non-HD and HD without manual intervention.
ram48335 is offline
post #6883 of 23552 Old 04-28-2008, 01:58 PM
Dayton's Avatar
The 650 doesn't have a default full screen setting. You may want to check to see if your cable box has such a setting.
Dayton is offline
post #6884 of 23552 Old 04-28-2008, 02:00 PM
jazzbass's Avatar
Set it on your SA3000 box. You can set it to wide 480i and it will also pass 1080i untouched.
jazzbass is offline
post #6885 of 23552 Old 04-28-2008, 02:01 PM
sharkcohen's Avatar
I've only been using the VGA input so far. Which HDMI input are trying to use for your PC? You should be using the HDMI2 input.
sharkcohen is offline
post #6886 of 23552 Old 04-28-2008, 02:43 PM
nitt4ever's Avatar
I was testing it on HDMI1. I did not know that you should be only using HDMI2. Does it say that in the manual (I should have read it)?
post #6887 of 23552 Old 04-28-2008, 02:46 PM
sharkcohen's Avatar
Yes
post #6888 of 23552 Old 04-28-2008, 02:52 PM
sd13's Avatar
Quoted: 29 Post(s)
im still within my 30-day window. During this time, i will consider other options. I already tried sony, but the smearing and ghosting is just too much. I dont know what else to buy?
sd13 is offline
post #6889 of 23552 Old 04-28-2008, 03:00 PM
ted08721's Avatar
Originally Posted by dafonz187 View Post
don't trust the ceva website for anything, give them a call, they don't seem to update the tracking on the website like fedex or ups do.
Don't bother calling main 800 number for Ceva, I got some lady that was most difficult, instead click on map till you get the area shipper close to you that set will be delivered to and call local number. I did that for northern Virginia which was located in Duelles, spoke to a lady named Kim who was very pleasant. Gave me the option of picking up set from them today or having the set delivered tomorrow. Btw I had ordered the set on the 4/23
ted08721 is offline
post #6890 of 23552 Old 04-28-2008, 03:00 PM
diabolyte's Avatar
wait for the new sony? or consider plasmas?
post #6891 of 23552 Old 04-28-2008, 03:04 PM
nitt4ever's Avatar
Mosh~~
I found this picture. I put it on a USB thumb drive and attached directly to my TV. I can see some banding near the top. Can you take a look at it and see if you can see it as well? Thanks.
http://img138.imageshack.us/img138/89/00709mn2.jpg
post #6892 of 23552 Old 04-28-2008, 03:12 PM
sd13's Avatar
Quoted: 29 Post(s)
im not sure yet. Burn-in is still an issue with plasmas, and the sonys will probably be really expensive. The a650 was perfect except for the 2 annoying lines. I thought my tv dilemma came to an end but i thought wrong.
sd13 is offline
post #6893 of 23552 Old 04-28-2008, 03:20 PM
Dayton's Avatar
I can see banding on that pick on my monitor, set to 32 bit color, as it downsizes to fit the browser window. I would guess that just about every display would have banding with that JPEG.
Dayton is offline
post #6894 of 23552 Old 04-28-2008, 03:27 PM
Ready2Mosh's Avatar
I se banding in the top of the picture on my laptop, I think it's the pic.
Mosh~~
post #6895 of 23552 Old 04-28-2008, 03:35 PM
bambam23's Avatar
does anyone else notice a little stutter( thats what i would call it anyway) after supercharging thier amp in the sm? I set it to 0's. I have a 360 hd drive hooked via hdmi, and was watching transformers. Just wondering if anyone else has noticed this?
bambam23 is offline
post #6896 of 23552 Old 04-28-2008, 03:46 PM
wiredman's Avatar
I'm ready to buy a new TV. Looking at the Sammy LN46A650 or the Toshiba 46XV540. I know everyone here is Sammy, & I agree, I like Samsung too! Does anyone have any thoughts on the Toshy?
Thx!!!
Monday......6 days a week???
wiredman is offline
post #6897 of 23552 Old 04-28-2008, 03:48 PM
superde1uxe's Avatar
a number of 650 owners have complained about the purple tint, and a few 750 owners see it also, so it's not just you. I've noticed it too while at BB and it gets really noticeable if you look at it from an angle. but of course not all sets have it, so you might jsut be one of the unlucky few to get it.
so i was in circuit city and i too noticed the purple fringe. the blue direcTV logo was on every screen in the place cuz someone powered down the box or something. there was a 71 and a 650 below it. i moved as far to the left as i could. 2 things i noticed. the 71 was clearer and bluer, and the 650 looked more purple and less clear the more i got away from center.
i think in their attempt to move away from the pure glossy of the 71 to something that is less reflective caused this. I mush prefered the 71 screen to the 650 as it was clearer and the colors were much more true.
just my 2cents. worth.
superde1uxe is offline
post #6898 of 23552 Old 04-28-2008, 03:55 PM
taurus2007's Avatar
Well, you can always check out the new Toshiba XF550!
Go 24
post #6899 of 23552 Old 04-28-2008, 03:58 PM
taurus2007's Avatar
Thx!!!
I think the problem with the new Toshiba models is that it's real hard to find anybody to carry them in store right now. I know a lot of people would like to have a look at the tv in person first before they purchase it. Not sure why Toshiba doesn't release their new lines to places like BB or CC. I guess they don't want to sell too many because I would have to build more.
Go 24
post #6900 of 23552 Old 04-28-2008, 04:13 PM
sharkcohen's Avatar
I must say that my 650 does have a purple haze to it, although it is hardly noticeable and I can't see it when viewing content, i.e. it is not giving me any picture color quality problems or purple blacks. It was more pronounced with the backlight up at full with no powersave. It certainly doesn't look as bad as the couple of pics that have been posted in this thread.
Reply LCD Flat Panel Displays
<<. , Lcd Hdtv , Samsung 19 Inch Lcd Hdtv Ln19a650 , Samsung 37 Inch Lcd Hdtv Ln37a550
