Official Samsung LNxxA650 Owner's Thread - Page 706 - AVS Forum | Home Theater Discussions And Reviews
post #21151 of 23557 Old 02-16-2009, 01:02 PM
fireballz's Avatar
hey guys i have a quick audio question. I own the 46" 650 (FW 1003.2 i believe).
I have my tv connected via HDMI to my STB (SA4250HD).
On some programming in very quiet scenes (for example, only dialogue with no other apparent audio such as music or background noise) the audio seems to go completely silent (like in between the dialogue). Now I know it is probably supposed to be very quiet, but it turns silent like the TV is off. This doesn't sound right because usually there is some sort of feedback noise or something (like wind/air). It just sounds odd when it goes completely silent, to some dialogue, to completely silent again, etc. Also you can hear some faint crackling noise as well when it is very very quiet. When there is other background noise/music, this problem doesn't occur.
So any ideas? Is it a settings/HDMI/STB issue?
fireballz is offline
post #21152 of 23557 Old 02-16-2009, 01:03 PM
phousley's Avatar
Originally Posted by vbgregg View Post
Does anyone make an adapter that goes from RF to some other connector, such as HDMI? In some sense, a cable box functions as such an adapter (and much more), but I don't need (or want to pay for) all the other functions of a cable box. Or is there some sort of inexpensive cable box that I could buy (rather than rent from Time Warner)?
What you're basically describing is an external HD tuner.
SA8300HDC - ODN 5.2.0_9 - 1TB eSATA
phousley is offline
post #21153 of 23557 Old 02-16-2009, 01:30 PM
Bravia's Avatar
I'm having the same problem. When I turn off the option that automatically levels the audio (I forget what Samsung calls it), the problem seems to go away. Still, that means I'm not able to use that feature. I'm not sure if this is a firmware issue or something else.
Bravia is offline
post #21154 of 23557 Old 02-16-2009, 01:38 PM
chumpy's Avatar
Would someone with firmware version 2004.x please tell me the firmware build date on their set? It's the long string of numbers and letters after pressing "Info" on the remote under "F/W Update." I am trying to get Samsung to send me the 2004.x firmware update and they need that build date number string...
LN46A650 - F/W: 2007.0 Panel Ver.: SQ01
Onkyo TX-SR706
DirecTV HR21-700
PS3, Wii, & NES
chumpy is offline
post #21155 of 23557 Old 02-16-2009, 01:42 PM
vbgregg's Avatar
Well, except that I don't need the tuner!
The TV has tuners for both over-the-air signals and cable TV signals, but only has one coaxial jack. If there is some adapter with a coaxial input jack and an HDMI output jack, then I could connect the cable TV cable directly to the coaxial jack on the TV and I could connect the over-the-air antenna cable to this adapter and then to an HDMI jack on the TV. Does anything like this exist (without an additional tuner)?
Gregg
vbgregg is offline
post #21156 of 23557 Old 02-16-2009, 02:21 PM
phousley's Avatar
Gregg
The coax contains the entire RF spectrum of TV channels, from which your TV tuner extracts a specific channel for display. An HDMI cable contains a single A/V stream supplied by a video device like a cable STB, DVD player, DRV, or external tuner. When you say you want to adapt your coax to HDMI, you have to have an external tuner to extract the single channel; either the cable company's STB or one you purchase.
phousley is offline
post #21157 of 23557 Old 02-16-2009, 02:59 PM
vbgregg's Avatar
Thanks for the help. I guess it's clear now that I don't know much about this stuff! It's too bad (for me, at least) that Samsung (and others) decided to only provide one coax jack. With 2 coax jacks, I guess one went to the CATV tuner and one went to the Antenna tuner. I think that Samsung (and others) still claim to have both QAM and ATSC tuners, so how does it work now? Does the single coax jack provide access to both tuners?
With regard to someone else's suggestion, can I use a splitter (backwards) to merge both the CATV and Antenna signals and feed that into the single coax jack on the TV? Will I be able to scan both for available channels?
Thanks in advance for your help,
Gregg
vbgregg is offline
post #21158 of 23557 Old 02-16-2009, 03:06 PM
felonyr301's Avatar
module: t-ambausc-2004.0, date: panel: 46a 71 , micom: t-ambausm-1005
rfs: t-ambausc- 20080416, 2008-08-05
*EDIT* Everything is capitalized if it matters... Also my sticker also says SS04... this is a LN46A650 model...
Xbox Live Gamertag: FELONY 301
PSN ID: FELONY--301
No problem adding people...
felonyr301 is offline
post #21159 of 23557 Old 02-16-2009, 03:38 PM
jp_tech's Avatar
Originally Posted by Helidoc View Post
Those are the service menu settings for the A650 that effect things per input. The notations above were the changes to those settings in the various firmware updates, as well as from the actual samsung service manual for the 32 40 46 & 52" sets. As far as my source guess you can say Samsung since it's their firmware and I have a hardcopy of the manual sitting in front of me suplied to me by samsung.
The 32" 650 doesn't have the same firmware updates the other models have.
jp_tech is offline
post #21160 of 23557 Old 02-16-2009, 06:07 PM
Helidoc's Avatar
Perhaps not, I've yet to see the 32" service menu or firmware, I included it as the service manual covers it as well. The point being was there have been changes in the wb during firmware updates.
Helidoc is offline
post #21161 of 23557 Old 02-16-2009, 09:16 PM
zzzzz's Avatar
Gregg
No you absolutely can not join CATV and antenna with a splitter like that. If you did, your antenna would "broadcast" the cable signal (albeit weakly) and the pic on your TV would look really bad.
What you want is an A/B switch. It has three RF connectors on the back (A, B and output). You can get a remote controlled one (which will allow you to switch it from the comfort of your couch) or you can get a regular one if you don't mind getting up to switch it back and forth. Radio Shack used to carry the remote controlled one; I'm not sure if they still do.
Run coax from your antenna to "A" on the A/B switch.
Run coax from cable wall plate to the "B" on the A/B switch.
Run coax from the center/output of the A/B switch to the RF input on the Samsung.
Put the A/B switch on A. Set the Samsung to antenna input and do a channel scan. Then put the A/B switch on B, set the Samsung to cable and do another channel scan. The TV will memorize each set of channels separately.
Then when you want to watch TV off the antenna, set the A/B switch to A and use the Tools menu on the TV to switch to antenna. When you want to watch cable, set the A/B switch to B and use the Tools menu to switch to cable.
zzzzz is offline
post #21162 of 23557 Old 02-17-2009, 01:50 AM
loinbread's Avatar
A quick, slightly paranoid query. I was cleaning the screen today, having just received a unit (the LA32A650 - Australian model, hence the 'LA'). Being aware of the glossy coating, I was wondering if the cleaning solution I am using can have any affect on it or would be able to damage. It is a alcohol-free solution designed for LCD and Plasma screens that came as part of a TV-cleaning kit. Thanks!
loinbread is offline
post #21163 of 23557 Old 02-17-2009, 04:50 AM
rebs's Avatar
I went with a friend to look for a new tv and I took him to BB and CC. The prices at CC are still not sale prices, LN46A650 was still a hundred more than I paid at BB. I looked at almost all the panel stickers on the side of the display models and found that almost all at both stores were SQ01 panels and a couple SS04 panels. To tell the truth I did not see anything special about these SQ01 panels, they looked the same as SS04 and a few seemed to have a poorer picture. I know the signal in a store is not what you get at home on cable or sat when you figure how many tvs they are feeding is a store, but these SQ01 panels did not seem special at all. Even on a couple that were playing blu-rays. I took my Harmony remote and played alittle with the settings and some had the wow 3-d soap kind of look and some didn't.
I have a question to ask, how many of you guys want the wow 3-d soap kind of picture and how many want a realistic looking vibrant bright sharp picture ?
rebs is offline
post #21164 of 23557 Old 02-17-2009, 07:36 AM
Mtnmike's Avatar
I guess we all need your definition of WOW. Simply because its all in the eye of the beholder. If you are looking for perfection you will never find it.
Mtnmike is offline
post #21165 of 23557 Old 02-17-2009, 08:01 AM
robusto400's Avatar
Quoted: 42 Post(s)
From what I have researched from other threads only the 750 has network capability (DLNA). However I am also goint to be getting a Samsung BD-P2550 which can stream Netflix movies so that should take care of that part. As connecting your TV to more internet sources become available won't other devices eventually offer this is a "client" so your TV really does not have to have this capability? Has ANYONE had any experience with using the DLNA functionality on the 750 and if so what was your experience? Thanks and in need of information before I write the check.
TV: Samsung UN65JU7100
AVR: Denon 2809CI
BD: Samsung FM57C
7.1 Speakers: Front - Polk RM30, Center - Polk Csi5, Surround (4) - Polk OWM3, Sub - Martin Logan Abyss
robusto400 is offline
post #21166 of 23557 Old 02-17-2009, 08:08 AM
chumpy's Avatar
Thanks bro. We'll see what happens if anything.
Onkyo TX-SR706
DirecTV HR21-700
PS3, Wii, & NES
chumpy is offline
post #21167 of 23557 Old 02-17-2009, 08:27 AM
gmanvbva's Avatar
If you get this, please let us know. I would be interested in having this, in case I ever want to consider upgrading the firmware.
gmanvbva is offline
post #21168 of 23557 Old 02-17-2009, 10:36 AM
rebs's Avatar
by wow I mean the soap, 3-d kind of look, looks like you are right in the picture, if you know what I mean. But I am having thoughts that the soap, 3-d look might not be so desirable after all.
I watched the daytona 500 yesterday and it looked great no blurring just a great picture. I think that look comes when to turn AMP on, I could be wrong. However I do not get it on my tv, like I did on the first one and maybe thats a good thing. I have no flashlights, clouding or purple haze and the picture looks good at an angle as well.
What I meant in the previous post was that I didn't see a big difference in the different panels I seen at CC and BB on display. I think I understand now that all these different panels can be good, bad or mediocre. Mtnmike is right it is in the eye of the beholder what they like and want to see.
Mtnmike, your advice and help has helped me alot, I appreciate everything. The guys on here are lucky to have you on here with your knowledge. Not to slight anyone, there are others on here that can be very helpful as well.
rebs is offline
post #21169 of 23557 Old 02-17-2009, 11:10 AM
rkfast's Avatar
Can I get a good reccomendation on how to clean a dusty bezel and avoid scratching it?
I used the supplied cloth and results werent so good.
Whats the best method?
rkfast is offline
post #21170 of 23557 Old 02-17-2009, 11:44 AM
Koochick's Avatar
You're a good person.
Koochick is offline
post #21171 of 23557 Old 02-17-2009, 11:58 AM
Biddy's Avatar
what is the general consensus of this beast? I have about 1100 max to spend on an lcd to replace my westinghouse 37w3 (bless it's heart its been great)
i do alot of gaming, and blu ray watching....360/ps3/and wii....i have a switch in my entertainment center already for the "info link" which seems interesting
can you update firmware there?
fry's has the 40" 650 for 1199 w/ free shipping...
Biddy is offline
post #21172 of 23557 Old 02-17-2009, 12:47 PM
Dayton's Avatar
Whatever you wipe the TV with, it should be very damp. Scratching occurs from pushing the dust over a dry surface. So you need to wipe off the dust with something very damp and then follow that up with with a dry micro-fiber cloth to prevent streaking. I just use e-tronic wipes, since they are very wet, to take off the dust and then follow that up with a clean dry micro-fiber cloth. My bezel and stand are scratch free and look like new, so it seems to be an okay solution.
Dayton is offline
post #21173 of 23557 Old 02-17-2009, 02:36 PM
cberasi's Avatar
Hello, new here and haven't had time to read through all the threads yet but will begin to work on out.
I just ordered the Samsung Ln46a650 a week or two ago and got it plugged in on 2/12/09. It worked fine for the 5 or 6 hours I used it, blu ray on ps3 with hdmi cord worked great and no problems with the cable.
Yesterday, 2/16 I went to time warner cable to upgrade my box to the HD box. Well I came home and plugged it in using the same HDMI cable I bought and am using for the ps3 with no problems. However when viewing cable televsion on source HDMI 3, which is what i have the box plugged into, it will not work as the picture intervals between being clear and fine for 30 seconds or so to being all static black and white with the fuzz sound for 30 seconds. However, when I view the television on source "TV" there is no problem and the cable works fine but is not up to HD.
With this situation, it seems that the box and cable output are not the problem, does this mean the problem most likely is with the HDMI cord I am using or did I hook something up incorrectly most likely?
Thx for your help
cberasi is offline
post #21174 of 23557 Old 02-17-2009, 06:00 PM
vbgregg's Avatar
I thought the splitter idea sounded too good to be true. By the way, a guy in Samsung's tech support was the one who suggested this!
I figured I'd probably have to use an A/B switch, but I thought I'd ask to see if there were any other options. Thanks,
Gregg
vbgregg is offline
post #21175 of 23557 Old 02-17-2009, 06:37 PM
NLN987S's Avatar
Thx for your help
Try using component cables from your HD box and see if the problem still persists.
BD=870
NLN987S is offline
post #21176 of 23557 Old 02-17-2009, 07:29 PM
sigmaace01's Avatar
After ordering the 46" a month ago, I'm finally getting it Saturday. I have 1 more "dumb" question. Is there any difference in HDMI 1, 2, or 3? I'm only hooking up a Directv HR20 & a Panny Blu-Ray DMP-BD35K.
sigmaace01 is offline
post #21177 of 23557 Old 02-17-2009, 08:07 PM
Opuntia's Avatar
I've been wondering about this myself, thanks for the great explanation.
Opuntia is offline
post #21178 of 23557 Old 02-17-2009, 09:54 PM
protechie's Avatar
I believe PC mode is only available on HDMI 2, so if you don't need that one you could leave it free in case you hook up your computer later on.
Samsung LN52A650, Denon AVR-1908, Klipsch Reference 7.1, Harmony One, Comcast Moto DC6412III, XBOX 360 Elite, PS3 80GB, WII
protechie is offline
post #21179 of 23557 Old 02-17-2009, 10:07 PM
cindyh's Avatar
Quoted: 20 Post(s)
Hi all.. I have recently purchased the Toshiba Regza 550u series 46 inch through Costco and was told it was a Samsung panel, but I have not been thrilled with the picture.
I keep looking at this Samsung LN46A650 at Best Buy and it looks great in the store, i just wonder what the main differences would be, they are both 120 hz, i just want to get a tv that will last a long time and look good I use Dish Network and watch HD but also a lot of SD as well.
ANy input on this before i buy it.. I noticed even on amazon and best buys websites everyone seems to love the Samsungs.. well not everyone, but enough to make me look at it
thanks in advance
cindyh is offline
post #21180 of 23557 Old 02-17-2009, 11:22 PM
wtfer's Avatar
Quoted: 225 Post(s)
Liked: 57
thanks in advance
Well the Samsung would definitely have better blacks & contrast as for SD it would still be pretty weak.
wtfer is offline
Reply LCD Flat Panel Displays
<<. , Lcd Hdtv , Samsung 19 Inch Lcd Hdtv Ln19a650 , Samsung 37 Inch Lcd Hdtv Ln37a550
