Official Samsung LNxxA650 Owner's Thread - Page 709 - AVS Forum | Home Theater Discussions And Reviews
Old 02-20-2009, 06:50 PM
phousley's Avatar
Originally Posted by DonM77 View Post
Thanks for the responce. The HD Box is a non DVR set and has HDMI. The box is set to....1080i yes. No receiver at this point. I wondering if I should swap out the HDMI cables.
HDMI is digital. If your picture is not breaking up, you're not going to get any improvement with a different cable. It either works or it doesn't.
SA8300HDC - ODN 5.2.0_9 - 1TB eSATA
phousley is offline
Old 02-20-2009, 08:40 PM
portwineboy's Avatar
Hi all. Just bought a LN-46A630 and I'm having a problem getting my Xbox 360 to output 1080p over component. I use an Onkyo 705 for switching and except for the 360 component, everything else is HDMI. When I select 1080p from the 360 HDTV Settings I get "Searching for signals, no signal" and back to the setup menu, leading me to believe it won't work.
Would anyone know if it's the TV or the receiver that is causing this problem? I'm upgrading the XBOX at some point, but I'd like to see my HD-DVDs in 1080p like my Blu-Rays.
portwineboy is offline
Old 02-21-2009, 02:09 AM
slbynum's Avatar
Try the component cables directly to the tv... if still no go then likely the tv cannot pass 1080p via component. My old Samsung DLP couldnt pass 1080p via component either.
slbynum is offline
Old 02-21-2009, 05:49 AM
DonM77's Avatar
Originally Posted by jp_tech View Post
Not sure if another HDMI cable will help but worth a shot. Does your cable have a lot of splits in your house? Maybe a signal strength problem. Not sure what else it could be.
To check the firmware go into the Menu-Setup-highlight SW Upgrade and then press the info button and you will see it at the bottom.
There are currently three splits. Two of them are in use, the other one is in my sons room. Next week i have someone coming out to add a wall mount in another room that doesn't currently have a connection.
What is the latest firmware upgrade? My Tv was built in Jan and is the SS04 Version. I'll look for the firmware version....ok I'm not sure which number I'm looking for here. So it's either 2008.9 or 1005?
DonM77 is offline
Old 02-21-2009, 07:11 AM
RockyMountainD's Avatar
2008.9 is the most recent.
RockyMountainD is offline
Old 02-21-2009, 07:30 AM
DonM77's Avatar
Originally Posted by Dayton View Post
There is only so much one can expect from broadcast HD. That said, primetime shows like Lost should look pretty good but you shouldn't expect it to compare to Blu-ray or HD DVD. For example, Lost Season 3 on Blu-ray is amazing and allows one to see what can't be done with broadcast HD.
Sure I get that. I was simply ruling out the tv by reffering to the Blu-ray movies. I'm watching CSN-HD and I'm flipping to the Non HD CSN channel and there is no noticable difference in picture quality. Surely the difference would be night and day, no?
DonM77 is offline
Old 02-21-2009, 07:37 AM
Lovehidef's Avatar
Being a realitively newcomer to the 120hz instead of my 4665 which died 13 months after I purchased it, I am seeing some blurring at fast motion speeds. One really bad area is on Versus TV thru Dish when they show bull riding. What do I need to do to make sure its on and getting the clearest picture?
Lovehidef is offline
Old 02-21-2009, 07:54 AM
Jeff909's Avatar
I just got the 46 650 at fry's a week ago. It was built in feb 2009. The screen is a sx06. Is this a samsung screen? Is it one worth keeping? No clouds or flashlights. But is it as good as the first ones that came out?
Jeff909 is offline
Old 02-21-2009, 08:47 AM
Mtnmike's Avatar
It would appear in all probability your problem is source related and most likely Comcrap errr Comcast. I would say a service call from them is in order or a move to Satellite TV. DirecTV does a pretty good job with signal, equipment and HD line-up. They also give great deals to new customers dumping Comcast.
Mtnmike is offline
Old 02-21-2009, 08:51 AM
Mtnmike's Avatar
Is it worth keeping? Surely if one of us said "no its not", that statement would not cause you to get rid of it now would it? There is no one here but you who can decide for you if what you just bought (including you TV) is worth keeping.
Mtnmike is offline
Old 02-21-2009, 09:00 AM
DonM77's Avatar
Yeah I'm stuck with comcast till Fios is available in my area. I'm with comcast for the local sports...and I'm expecting a Night and day difference with their HD service, would that be accurate?
DonM77 is offline
Old 02-21-2009, 09:20 AM
Jeff909's Avatar
I guess it sounded stupid. But is this a second rate screen? Is it a samsung panel or a second tier supplier? I have had th e650 before and this one has no pop. Thanks for the opinion. Took it back to frys. Got an XBR.
Jeff909 is offline
Old 02-21-2009, 09:38 AM
gmanvbva's Avatar
I have comcast in my area (VA) and while they were implementing some HD channels it appeared they were initially broadcasting SD on the HD channel for a period before they actually had a true HD source. Perhaps this is the issue? If I remember correctly Comcast Sports Net was one of those.
Also, even on stations in HD, the HD quality can change noticeably. For example my local ABC channel is usually average but during NBA game broadcasts, there is a significant difference (for the better) in the HD quality. I even had to have my cable signal boosted because during these games the signal would come in and out at times (while all other channels worked fine). This was the only time I ever had issue with losing signal and it was apparently because the broadcast was using more BW due to the quality.
gmanvbva is offline
Old 02-21-2009, 11:38 AM
okeefe's Avatar
Does the Samsung 52" LNA650 have a digital PIP? I've read where the 52" LNA550 had an analog PIP, therefore, rendering it useless.
okeefe is offline
samsvoc's Avatar
I believe ver.2007.0 is the latest.
samsvoc is offline
Old 02-21-2009, 12:00 PM
phousley's Avatar
No, analog tuner only.
phousley is offline
Old 02-21-2009, 02:35 PM
gmanvbva's Avatar
2008.9 is the most recent version shipping on TV's. (has been shipping for a couple months now)
2007.0 is the most recent available for download from Samsung support site.
gmanvbva is offline
Old 02-21-2009, 02:54 PM
Orta's Avatar
The S supposedly designates it's a Samsung panel, but there are several versions of S--SQ, SX, SS, etc, and of course the numbers. In the 61/65 model last year, I think people pieced together than these changes actually correlated with swaps from 10bit to 8bit panels. They could be doing the same thing this year, but I don't think I've seen any proof. I believe there are German and Russian sites with a lot more info on it, but most people here can't read, follow, or translate it.
Orta is offline
Old 02-21-2009, 03:54 PM
sigmaace01's Avatar
My 650 came today...I'm in heaven! Amazing PQ, I have no complaints.
LoL...After registering my TV, I found out the manufacture date is a week away...2-28-09.
sigmaace01 is offline
Old 02-21-2009, 04:12 PM
wtfo's Avatar
Quoted: 12 Post(s)
where can 2008.9 be found? And do we know what it fixes?
~alan
LG OLED65B6P (yay!)
Denon AVR-X4200
wtfo is offline
Old 02-21-2009, 04:51 PM
aftermidnight's Avatar
Opinions please. I just bought another LN52A650 from Amazon, this one for my mother, which was delivered just yesterday. It has a build date of 8/5/08, firmware 2004-0. I’m thinking the build date is awful old (6+ months) for such a popular set. Is this possibly a return? It had the 2 white plastic straps on the outside of the box, plastic covering the base, the soft Styrofoam sheet covering the whole TV but I can’t recall if the bezel had the plastic on it. There were also no stickers on the left bezel like the one I received last June. The manual/remote bag had a hole in it but I’m not certain if the delivery guy did that or not. The remote was in its wrap and the batteries were sealed. The bezel/screen has no scratches and there are no dead/stuck pixels and the picture looks fantastic so far. No clouding, minor flashlighting in 2 corners (not bad though – tolerable)
We live in Indianapolis, not a podunk town, so the old build date has me concerned. Should I be you think? The TV sure looked new, but maybe Amazon/Samsung has gotten better disguising their returns that are resold as new. If it’s used, who do you think repackaged it, Amazon or Samsung? The thought of paying $1759 for a used TV makes my stomach ache. I have 30 days to return it if need be. What would you do?
aftermidnight is offline
Old 02-21-2009, 05:04 PM
felonyr301's Avatar
You can't only 1080p component works for games not hd-dvd or upscaling dvds. It's not a microsoft thing blame it on the copyright protection crap.
To watch hd-dvd, blu-ray, and upscaling dvds to 1080p you have to have hdmi connection or for the 360 hd-dvd and upscaling dvds you can also get by using the vga connection. Component 1080ps works for gaming only.
Xbox Live Gamertag: FELONY 301
PSN ID: FELONY--301
No problem adding people...
felonyr301 is offline
Old 02-21-2009, 05:19 PM
gmanvbva's Avatar
It can not be found anywhere other than installed on a newly shipped TV.
There are no real "release notes" stating the changes from FW to FW.
There is only speculation what each FW might address.
gmanvbva is offline
Old 02-21-2009, 05:26 PM
gmanvbva's Avatar
Originally Posted by aftermidnight View Post
Opinions please. I just bought another LN52A650 from Amazon, this one for my mother, which was delivered just yesterday. It has a build date of 8/5/08, firmware 2004-0. I'm thinking the build date is awful old (6+ months) for such a popular set. Is this possibly a return? It had the 2 white plastic straps on the outside of the box, plastic covering the base, the soft Styrofoam sheet covering the whole TV but I can't recall if the bezel had the plastic on it. There were also no stickers on the left bezel like the one I received last June. The manual/remote bag had a hole in it but I'm not certain if the delivery guy did that or not. The remote was in its wrap and the batteries were sealed. The bezel/screen has no scratches and there are no dead/stuck pixels and the picture looks fantastic so far. No clouding, minor flashlighting in 2 corners (not bad though - tolerable)
We live in Indianapolis, not a podunk town, so the old build date has me concerned. Should I be you think? The TV sure looked new, but maybe Amazon/Samsung has gotten better disguising their returns that are resold as new. If it's used, who do you think repackaged it, Amazon or Samsung? The thought of paying $1759 for a used TV makes my stomach ache. I have 30 days to return it if need be. What would you do?
Who knows? It could be possible that there was in whatever warehouse amazon shipped yours from that was just sitting around for a few months?
Or it could have been a return that was never opened and took a couple months to turn around and be restocked?
If it is going to keep you up at night, return it.
gmanvbva is offline
Old 02-21-2009, 05:34 PM
gmanvbva's Avatar
Here is an article listing the capabilities for component and vga on the Xbox 360.
VGA:
* HD DVD - 1080p resolution and all others
* DVD - Upscaled as high as 1080p resolution and all others
* Games - 720p games upscaled to 1080p, also supports native-1080p games in the future
Component:
* HD DVD - 1080i resolution maximum, limited by AACS
* DVD - Upscaled to 480p maximum, limited by CSS
http://w.engadgethd.com/2006/09/21/x...ent-1080p-vga/
gmanvbva is offline
Old 02-21-2009, 05:38 PM
Lovehidef's Avatar
Is 120hz on?
Old 02-21-2009, 06:23 PM
gmanvbva's Avatar
Originally Posted by Lovehidef View Post
Is 120hz on?
120hz is always on. It is the frequency the panel operates at.
AMP is used in conjunction with 120hz.
AMP can be adjusted, so you will want to adjust it to your preference.
gmanvbva is offline
Old 02-21-2009, 07:00 PM
DonM77's Avatar
Well I figuared out what the problem was... the source setting was set on "TV". The HD Box is plugged into HDMI-3. I simply changed the source to HDMI-3. Problem solved!
DonM77 is offline
Lovehidef's Avatar
thanks....
Old 02-21-2009, 07:39 PM
jp_tech's Avatar
Glad to hear. I was just going to say I'm watching Rambo 2 on AMC HD and flipped over to AMC SD and the difference is night and day.
jp_tech is offline
<<. , Lcd Hdtv , Samsung 19 Inch Lcd Hdtv Ln19a650 , Samsung 37 Inch Lcd Hdtv Ln37a550
